- Quick Menu
| Diesel Engine Forum This is a new forum dedicated to diesel engines and their applicable accessories. |
12-08-2011
Basically, I’m trying to balance my time winterizing with making the engine last.
Since I’m retired, I’m more concerned about latter.
My practice has been to use the least expensive RV antifreeze. It's usually about $4 per gallon and says it's good for -50 and contains a corrosion inhibitor. To that I add some Prestone “Cooling System/Antifreeze Treatment” that claims it protects against cooling system corrosion. West Marine has products that range from 5 to 26 per gallon. It’s not real clear, to me, how much any of them do for corrosion protection. But, again, my main concern is whether to keep the system full or partially drained.
I DO like to flush the system with fresh water in the fall and to do this, I must remove the thermostat and impeller. I then use an external pump for the flush. When I see what comes out, I’m convinced that this is worth doing.
So, my plan will be to keep the system full. But I’m still not sure how to get it into the exhaust system without chancing getting it back into the exhaust portion of the exhaust manifold. I don’t believe my muffler has a drain.
12-08-2011
Senior Smart Aleck
I bought the expensive ($25/gallon), environmentally-safe, antifreeze from West for the engine coolant change and raw water intake flush.
WalMart sells $4 a gallon, pink, RV potable water antifreeze to winterize your water tank. You simply flush it out with fresh water to de-winterize. I pumped a gallon through the water system to prevent the pipes from freezing and emptied another gallon into the marine head holding tank (after pumping out).
Is what you are referring to? Are you sure that is safe to put into the engine raw water intake?
12-08-2011
There is a difference between winterization anti freeze and coolant antifreeze. The later can be very expensive and not appropriate for winterizing the raw water intake.
The -50 deg (pink stuff) is usually between $4 and $6 per gallon. You have to be fairly sure that it is not mixed with water, or it will quickly lose its protective ability. The -50 rating is the temp at which it will protect against expansive bursting, it will freeze at a much higher temp and that temp goes up quickly when diluted.
-100 deg (blue) can be mixed with equal parts water and essentially becomes -50, IIRC. It usually sells for $10 to $12 per gallon. It is best for applications where it may mix internally with the water it is displacing. This is most common in engines, where the raw water may flow over top of dips that hold onto water. Once you stop pumping the antifreeze, the residual water mixes with the AF and dilutes that portion anyway.
By the way, some brands are pure, some are recycled aircraft deicer, if you care. That can account for the price difference.
Jeanneau 54DS
12-08-2011
Senior Smart Aleck
What's wrong with using coolant in the raw water intake (other than the expense)?
12-08-2011
Hmmmm. As usual, these threads get you thinking and make you smarter. What I have been using is the Walmart stuff. At $4 per gallon, I'm almost certain it is the same stuff that WM sells for $5. Last year it was labeled as a Dow product. What I used a few weeks ago is labeled as a "Super Tech" product. These and the WM 5 dollar stuff all say they are good for -50 and contain corrosion inhibitors. I suspect it's all the same stuff from the same plant. I have used the same stuff in the engine and the water system.
I know that my procedure does not result in zero dilution. I have never had any damage but I do plan to use a lower temperature antifreeze in the future - for that reason. Our winters typically don't go below zero but I'd rather be safe (given the dilution).
BTW, another thing I typically do to limit the dilution is to blow and then vacuum everything I can out of everything I winterize using my wet vac.
12-08-2011
Senior Smart Aleck
The West Marine Pure Oceans Engine Antifreeze & Coolant (green color) is propylene gylcol, with a recommendation to mix with water from 50/50 to 66/34.
The (WalMart) SuperTech RV & Marine Antifreeze is also propylene gycol, already mixed with water, but also has ethyl alchohol, Di Potassium Phosphate, colorant, and fragrance. It includes a warning:
Caution: not intended for use in engines as antifreeze/coolant, marine engines, closed boiler systems or solar collections.
12-08-2011
Will need some chemical guru to give you a better answer, but engine coolants typically say on the bottle not to use them at full strength. I don't know why. I think they are close to pure product. At the least, they are a waste of money with no added benefit I'm aware of.
Worst case, some are not environmentally friendly like the winterization fluids.
Jeanneau 54DS
12-10-2011
Chuck....
You said....
So take out the T-stat first and then you don't have to worry if it is opened or closed
....unquote.
That is an idea there Chuck, but can you be sure it's mixing enough with the jacket water? The Volvo raw water cooling operates by the thermostat opening and the flow periodically skimming the hot water off the top of the barrels and cylinder head. There is no formal throughput through the barrels.
Even with thermostat out, will it mix enough?
I have a cracked aft barrel as witness to me getting it wrong (for other reasons than anti-freeze).
I nearly lost the whole motor. All the core plugs had blown and that saved a total loss.
Pls be careful.
Rockter.
12-10-2011
Another point, the wee fluid entry ports for the "skimming" are quite small, little more than the diameter of a pencil. They are prone to scaling, and they can virtually bridge off. The net result is that the motor slowly overheats. On shut-down you can hear the water in there boiling.
It's dead easy to fix. Take off the exhaust manifoild and use a broad blade screwdriver to remove the scaling. It has a heavily-staining, black, almost bituminous appearance to it.
Exhaust gaskets are expensive, however.
AND!!!!... make sure you do not put them on in poor light. I did, and got one of them the wrong way round. Net result, seawater comes out of the air filter on shut-down.
One of the darkest moments I have ever had.
And it took us some time to figure out what had been done wrong.
A last point, if anyone ever has a leaking gearbox seal on that motor, and the new seal leaks too, send me a PM. I have a learing curve 3 weeks long before we could fix it, and it was SO simple to do, in the end.
Rockter.
| Thread Tools |
Search this Thread |
