01-21-2012
"Really, if the crush washers are in good condition, "
Often they can be (and are) re-used, but really, the entire point of a crush washer is that it deforms during normal installation, to mate two pieces of metal that are not machined to a perfect tolerance.
So unless you are very lucky, and the two pieces of metal were perfectly machined, parallel and smooth, the crush washer does deform on installation. If it is thick enough and the deformation is small, you can crush it again and still have it fill the gap. But it is very much like a high-pressure version of plumbers putty or window glazing putty: Once it squeezes out, it doesn't flow back, it really should be replaced.
Unless your engine loves you more than most of the duplicitous beasts do. They usually just like to wait for the least convenient moment, and THEN that crush washer starts sucking in air. You know what happens next.
