01-14-2012
Originally Posted by boatpoker
I much prefer a flow detector alarm in my raw water line to an overtemperature alarm. The flow detector will set off the alarm the very instant that cooling water ceases to flow. By the time an OT alarm goes off, your impeller is certainly fried, most likely your raw water pump and you are well on your way to engine damage. I have Aqualarm flow detectors on my main and my generator intakes..... wouldn't be without them.
I agree, or should say, used to agree. Irony being what it is, I was told of the high failure rate of flow alarms right here on this forum and I have one for the same reason you point out.
Very coincidentally, during winterization this year and running the engine up to temp to change the oil, the seacock is accidentally left closed for the start. No alarm.
Jeanneau 54DS
