03-01-2012
The poster states his engine runs away for no apparent reason.
If people replying to this post think it (OP's problem) could be related to lubrication oil being driven through the rings causing such a perfect combustion that: a highly precision built; one cylinder; high compression; 3200rpm revving; with very delicate timing; and a precise injection system; 8hp diesel engine could run out of control: then you all need to TAKE ONE APART.
Seriously, the bloke with the Comby motor had five run-down cylinders, pushing away a very tired 6 cylinder motor. He attributes his claim that diesel engines run out of control because of an oil leak through the rings!
DIESEL ENGINES/MOTORS DO NOT RUN ON THEIR OWN LUBRICATION OIL. FACT!
Take one apart. No, take 3 apart, like I have, and get them to start, AND RUN.
I know what the problem with posting on a sailing forum is: you people change the oil in your engines as much as you change your underwear.
If you can't read between these lines then I will help.
The rack and pinion fuel distributor is within the oil sump (connected to the fuel pump). I you do not keep this item religiously clean( through changing the oil), it foul, and cause irratic behaviour with your motor
