Go Back   SailNet Community > General Interest Forums > Gear & Maintenance > Diesel Engine Forum
Diesel Engine Forum This is a new forum dedicated to diesel engines and their applicable accessories.
Like Tree2Likes
Old 01-30-2012
mikey19625 is on a distinguished road
Water in the cylinder
I have a 4eoz Kohler Genset with a Farymann Diesel 18W engine. I just overhauled the engine with a new head, cylinder, all new gaskets and orings. The engine starts and runs for about 40 minutes until i shut it down. When i restarted it ran for about 3 minutes and it shut down it self. I pulled the injector out and the top of the piston was full of water. This has happened twice after reassembling the engine. i checked the compression and it's excellent. Any ideas or past experience?
Old 01-31-2012
Hartley18's Avatar
Termite Fodder
Hartley18 will become famous soon enough Hartley18 will become famous soon enough
Blocked exhaust siphon breaker?
Crew member on the Womboat for:
2011 Heaven Can Wait 24Hr - Race against Cancer.
Old 01-31-2012
mm2187 is on a distinguished road
I am guessing it is a raw water cooled engine.. Did you remove the pistons and cleanthe cylinders to get all the water salt and all the other junk out? Do you have water coming out of the exhaust as if it were normally functioning? When putting the gaskets in did you torque all screws back to specification. you could easily overtorque and ruine the gaskets causing a leak.
Schock - New York 36
Portsmouth, RI
Old 01-31-2012
water in the cylinder
it is a raw water cooled engine. Water is coming out of the exhaust as it normally does. The cylinder is new with new rings. cleaned everything and torqued to specifications with a new head gasket every time i've taken it apart. i haven't inspected the Siphon Break (Reed Valve) for blockages (i hope that's what Hartley18 was referring to) or the exhaust manifold mixing elbow. i will soon. Any other ideas?
Old 01-31-2012
If the engine always started promptly it's unlikely that the exhaust cooling water is getting back into the engine - esp if the engine was running and shut down due to water intrusion.
Sounds more like a cracked water jacket or, despite best efforts, a leaking head gasket (or a slightly 'wrong' one??) Disclaimer: not familiar with that particular engine..
1984 Fast/Nicholson 345
Old 01-31-2012
klem is on a distinguished road
Is it raw water cooled? If not, taste the water (but don't drink it, that would be gross).
Old 01-31-2012
It is a raw water cooled engine.
Old 01-31-2012
I agree with Faster... the engine would not start up if the cylinder was filled with water. I would also check the color of the oil to see if it has turned gray (which would be another location where the water has leaked).
Portsmouth, RI
Old 01-31-2012
this sympton has happended twice. after the first time I removed the head and the cylinder, cleaned everything and replaced the head gasket and o-rings. I torqued to specifications and it started right back. it ran for 40 minutes til I shut it down. Moments later I started it again without any problems and it ran for approximately 2 minutes, when it shut down itself. I removed the injector and there was water again. By the opinion of other people thu far it points to the Siphon Breaker being blocked. I'll ck it tonight.
Old 01-31-2012
Hartley18's Avatar
Termite Fodder
I don't think I've ever disagreed with anything Fast has posted before, but, having seen it happen myself, I will on this occasion.
If there's no evidence of water in the oil, check the Siphon Breaker.. yep, the Reed Valve thingy.
Faster likes this.
Bleeding a 3 Cylinder Diesel SawWhet Diesel Engine Forum 4 10-31-2011 06:02 PM
Volvo Penta 2 cylinder lottobemine Diesel Engine Forum 1 09-25-2011 12:31 PM
Cylinder Head Bolts puff6022 Gear & Maintenance 10 11-28-2010 10:30 PM
salt water in cylinder 3 Foxsaver Atomic 4 7 08-22-2009 11:32 PM
yanmar three cylinder edwinh Gear & Maintenance 2 08-31-2007 12:46 PM
