02-10-2012
Senior Slacker
I considered converting my 2gm20 to FW cooling. But, the guys at a diesel shop/parts-retailer (S&W Diesel, in Wilmington, CA) basically talked me out of it. They said that as long as the zincs are changed on a regular basis, corrosion isn't really a problem in these little Yanmars (with the exception of the mixing elbow). They pointed out that the part I brought in (the plate that holds the cylinder head zinc) essentially looked brand new once the salt was blasted off. Also, my guess is that it would cost you $1000 to $1500 to do the conversion. You might get a bit less carbon build up, and the emissions might go down a but at the higher operating temps. But, since the horsepower ratings are identical for the raw water and freshwater versions of these engines, I doubt there would be any significant increase in power. All together, it probably isn't worth the time or expense.
