Go Back   SailNet Community > General Interest Forums > Gear & Maintenance > Diesel Engine Forum
Diesel Engine Forum This is a new forum dedicated to diesel engines and their applicable accessories.
Like Tree3Likes
  #1
Old 06-13-2012
wph36 is on a distinguished road
Siezed perkins
41' Morgan been in storage a couple winters, and have gone down to crank engine (Perkins 4-154) every few months, with the last time being Oct 2011 ....went down recently, and can't budge it. Put a pipe wrench on it and no go. I'm supposing first thing would be to pull the injectors and get some unsiezing product, or plain old diesel in there ...can anyone else think of what next?
  #2
Old 06-13-2012
dabnis is on a distinguished road
Re: Siezed perkins
Perhaps the block froze and cracked from low temps causing coolant to leak down into the cylinders and cause hydro lock or corrosion between the pistons and cylinder walls, maybe bearing seizure also? If the coolant is low in the tank it may be inside the engine? Suggest you not force anything until you determine why it won't turn over. Removing the injectors would allow any coolant in the cylinders to escape.
Paul T
erps likes this.
  #3
Old 06-13-2012
sea_hunter's Avatar
Senior Cruiser
sea_hunter is on a distinguished road
Ouch. Not a good engine to have seized. Pull the injectors out and fill with WD40 or diesel. Let sit a couple of days and try the pipe wrench again with a cheater pipe. Sometimes if the engine was hydrolocked when winterized, water could have entered the cylinders and froze the engine. Make sure you flush the cylinders with fresh diesel before you reassemble. Good Luck
  #4
Old 06-14-2012
Re: Siezed perkins
Thks for the quick replies ..will get down there to look see. Looking at some of the postings here and other forums, I understand I may have an issue getting those injectors out ...apparently they don't necessarily slide out when loosened?
  #5
Old 06-14-2012
PorFin's Avatar
Señor Member
PorFin is on a distinguished road
Re: Siezed perkins
wph,
Yeah, the Perkins (CAV) injectors can give you a good fight. I recently pulled mine, the last time I had done it was four years ago -- they were reluctant to come out. The key is patience and persistence. A little PB Blaster, a little gentle leverage, and you'll be good to go.
  #6
Old 06-14-2012
Re: Siezed perkins
Googled those CAV injectors... yikes, can see the issue there. Very glad for my Bosch injectors - more like pulling a spark plug.
  #7
Old 06-14-2012
Re: Siezed perkins
If it has glow plugs they may be easier to pull out? If there is coolant in the cylinders it should come out the plug holes.
Paul T
  #8
Old 06-14-2012
PorFin's Avatar
Señor Member
Re: Siezed perkins
Paul T
Not sure about the 4.154, but do I know my 4.108 has no glow plugs.
I think pulling the injectors and having them pop tested is probably going to be a wise thing to do regardless of the cause of the engine seizure. May as well get it out of the way now while the enthusiasm and energy is relatively high.
  #9
Old 06-14-2012
CarelessNavigator's Avatar
CarelessNavigator is on a distinguished road
Re: Siezed perkins
You got me cringing with that pipe wrench. I would try removing the starter and get a pry bar on a tooth of the flywheel. The whole fulcrum lever thing works pretty good and will generate much more turning force with much less effort than a pipe wrench the chances of damaging anything and shouting lots of cus words will be much lower to.
  #10
Old 06-14-2012
bljones has a spectacular aura about bljones has a spectacular aura about
Re: Siezed perkins
No.
Quick way to bust flywheel teeth, and/or the bellhousing compared to the relativley mid torque applied at the crank which should already be able to deal with crank starting.
It's 5 o'clock somewhere:
You may post attachments
You may edit your posts
feed back on siezed rudder on Cal 28 sarafinadh Cal 0 08-23-2009 02:30 PM
Perkins 4-107 trecksail Gear & Maintenance 9 02-02-2009 07:35 PM
Perkins 4-108 sailaway50 Gear & Maintenance 1 01-19-2006 07:55 PM
Old Perkins 4-108 firemanbob Living Aboard 3 03-12-2005 07:55 AM
Perkins 4-107 tjkassen Gear & Maintenance 2 11-02-2004 01:38 PM
SEO by vBSEO 3.6.1
