Go Back   SailNet Community > General Interest Forums > Gear & Maintenance > Diesel Engine Forum
Diesel Engine Forum This is a new forum dedicated to diesel engines and their applicable accessories.
  #1
Old 07-09-2012
cd66312 is on a distinguished road
Petter AC1WM - Any other owners? Tips and tricks?
Hello, I recently purchased a boat with the Petter AC1WM 1 cylinder diesel. These were built some time in the early to late 70s and seem pretty rare in the 'states. This one has sat for a good 10 years or so without running though it was claimed at the time of purchase that PO rebuilt it. However this was a charity auction purchase and I have no way to contact actual PO.
I have her running pretty well after a long scare, turned out the fuel system just needed bleeding. I have oil filters and will be changing the oil today. Got a new impeller for the water pump. I installed a radiator flush kit in the water intake line to allow for running on the dry (she's a trailer sailer).
Anything else I should be looking out for before I can have the utmost faith in my engine?
  #2
Old 07-10-2012
NancySchwiesow is on a distinguished road
Re: Petter AC1WM - Any other owners? Tips and tricks?
We've enjoyed our AC1WM in a Balboa 8.2 for about 15 years. It's been reliable and easy starting.
There are reprints of some of the manuals on the web if you don't have them. R.A. Mitchell in New Bedford MA has been very helpful with parts. Are you aware of the fuel overload lever for easier starting? I made a linkage to activate it via flexible cable to avoid the need for direct access to the engine while starting. I replaced the copper washers on the banjo fittings on the secondary fuel filter with Parker stat-o-seal washers to avoid diesel seepage. Check the exhaust elbow. Ours rusted out from the inside. I replaced it with one from a salvage engine I have, but need to find new ones for both engines soon. The fuel system is self bleeding. You can circulate fuel back to the tank by operating a lever on the fuel lift pump with a finger without turning over the engine. I fit a standard zinc pencil from Hamilton with 3/8-16 male thread into the Petter plug with 7/16-18 female threads by jamming the threads with solder. This avoided the expensive Petter replacement.
  #3
Old 07-10-2012
djodenda's Avatar
djodenda will become famous soon enough djodenda will become famous soon enough
I had one on my Catalina 27 in the mid 80's. Engine was reliable, except that the salt water got the aluminum head, which killed it...
I remember there were was a spring washer that created the seal between the fuel injector and the head. You were supposed to replace it any time you removed the injector. Might be good to have a few of those around.
Enjoy your engine. Sounded like the African Queen!
David
1987 CS 36 Merlin "Kyrie"
  #4
Old 07-12-2012
Man, these 8.2 owners are just coming out of the woodwork. I was nearly convinced I had the last remaining one! My exhaust elbow is patched up as well. I have not taken the head off to check for pitting as it runs pretty good as is. What are people doing to preserve the head?
  #5
Old 08-17-2012
Ok, stupid question here, where is the oil filter on this thing. I swear, I've looked everywhere.
  #6
Old 01-14-2013
The oil filter is behind a cap on the lower left of the engine looking at the front. It's a bare cartridge type inserted in a horizontal well in the crankcase. Check some of the on-line manuals, if they're still there. There's a horizontal bolt with 1/2" head in the center of the cap for removal. I can order filter cartridges from my local NAPA store. NAPA 1629, Wix 51629.
You may post attachments
You may edit your posts
Tips and tricks for getting rid of crab/lobster floats MastUndSchotbruch Seamanship 29 08-12-2012 08:03 AM
Block Island tips and tricks Minnewaska US Northeast 5 08-12-2011 09:39 AM
Newbie advice - tips and tricks for buying/ maintaining classic wooden boats Adax General Discussion (sailing related) 61 06-11-2010 06:39 PM
The liveaboard tips and tricks thread! wind_magic Living Aboard 20 04-15-2010 05:37 PM
petter warwicksail Gear & Maintenance 12 12-21-2007 10:11 AM
SEO by vBSEO 3.6.1
