Go Back   SailNet Community > General Interest Forums > Gear & Maintenance > Diesel Engine Forum
Diesel Engine Forum This is a new forum dedicated to diesel engines and their applicable accessories.
Like Tree3Likes
  #1
Old 09-12-2012
AndreasNYC is on a distinguished road
repairing diesel engine on the dry
Hello Everyone
I am planning on doing some work on my diesel engine this winter.
I was initially planning to put the boat in dry dock and then work on it.
It has since occured to me that it would be trickier to test run the engine when there is no water supply to cool it.
how is this issue usually handled?
Do you just attach a bucket to the intake and outlet and let it circulate?
It seems that water would get hot pretty fast.
Also I am not sure the water pump can actually suck on the intake side so the bucket would have to be on the outside of the boat right by the intake?
any suggestions are welcome.
Andreas
  #2
Old 09-12-2012
erps's Avatar
the pointy end is the bow
Re: repairing diesel engine on the dry
Stick a plastic bucket or bin in the cockpit. Run a hose from the bucket to the motor intake. Put a garden hose from a spigot to the bucket to keep the bucket full while running the motor. Any excess water from the garden hose will spill out and run out the cockpit drains.
rikhall likes this.
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
  #3
Old 09-12-2012
leogallant's Avatar
leogallant is on a distinguished road
Check out videos on MaineSail's YouTube channel. He's got a good one on that very thing, as he shows how to winterize on the hard.
Leo
Journey to Charleston on Ubiquitous
Steve's Ubiquitous Blog
  #4
Old 09-12-2012
Thanks for the info guys
A
  #5
Old 09-12-2012
FSMike's Avatar
FSMike is on a distinguished road
Why not just stick a hose into the raw water intake?
Sail Fast Live Slow
40' Norman Cross trimaran
  #6
Old 09-12-2012
erps's Avatar
That would work, but it might be difficult to regulate the water flow and the pressure with spillage ending up in the bilge.
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
  #7
Old 09-12-2012
mjf55 is on a distinguished road
Originally Posted by leogallant View Post
Check out videos on MaineSail's YouTube channel...
I have read his articles but have not found a YouTube channel. Can you post a link for the YouTube challenged? Thanks
Sent from my Nexus 7 using Tapatalk 2
Mark
1975 Hunter30
  #8
Old 09-12-2012
CalebD's Avatar
Tartan 27' owner
CalebD will become famous soon enough
Hooking up a hose with shore side water pressure directly to the raw water intake is asking for trouble. The worst case scenario is you end up with water back flooding your manifold and into your cylinders - not good.
It is best to let the water pump regulate the amount of water and pull it in from a bucket as already mentioned.
BELLATRIX1965 and rikhall like this.
Everybody has one:
  #9
Old 09-12-2012
ECS-IB30's Avatar
Islander Yacht Fan
ECS-IB30 is on a distinguished road
West marine sells a plunger head fitted with a hose bib for just this purpose...works well...regulate water pressure with faucet ...
  #10
Old 09-12-2012
rikhall's Avatar
old guy :)
rikhall will become famous soon enough
I got an old large plastic bucket - the size industrial floor cleaner comes in. I bought a plastic thru-hull fitting the same size as my raw water intake and installed it on teh side of the bucket near the bottom of the bucket.
I take the raw water intake hose off of the water strainer and add a four foot length and attach that to my bucket thru-hull.
I start filling the bucket with a garden hose. I could run the motor as long as I like with this set up. DON'T put it in gear - your cutless bearing needs water for lubrication.
I use this each fall with potable antifreeze to winterize the engine and each May to start and test run the motor before launch.
There are at least a half dozen guys in the boat yard that "borrow" it each fall and spring.
Rik
Irwin Citation 34
You may post attachments
You may edit your posts
Looking for Used Diesel Engine Loper_27 Boat Review and Purchase Forum 2 06-04-2012 04:56 PM
Diesel engine course in SF bay MarkSF Learning to Sail 7 05-02-2011 05:40 PM
Best book on repairing marine diesel Summercamp Diesel Engine Forum 6 03-22-2010 10:09 PM
Diesel engine help patrickbwells Gear & Maintenance 15 04-01-2007 04:37 PM
Diesel Engine nancisboat Crew Wanted/Available 0 03-13-2001 08:49 AM
SEO by vBSEO 3.6.1
