Go Back   SailNet Community > General Interest Forums > Gear & Maintenance > Diesel Engine Forum
Diesel Engine Forum This is a new forum dedicated to diesel engines and their applicable accessories.
Like Tree1Likes
  • 1 Post By MarkSF
  #1
Old 10-27-2012
MarkSailor is on a distinguished road
How Hard To Push My Perkins
This may be a dumb question, but that has never stopped me before.
I have a 1994 vintage Perkins "Perama" 29 HP inboard diesel, with about 1300 hours on it, in a Catalina 320. I think the engine was fairly well maintained by the former owner, and I have tried to be good about changing oil, filters, etc.
The question is, how many RPMs would you push this engine at cruise or for short periods when trying to clear other traffic, etc.? I usually cruise between 2000 and 2500 RPM, but wonder if I am being too cautious. I have a service manual for the engine, but it doesn't address this question. Any advice?
Mark
S/V Reality
New Orleans, LA
  #2
Old 10-27-2012
SloopJonB's Avatar
Senior Moment Member
SloopJonB will become famous soon enough
Re: How Hard To Push My Perkins
Don't your documents list a Max recommended RPM? That's the number you are looking for. A Perkins dealer should have it.
I, myself, personally intend to continue being outspoken, opinionated, intolerant of all fanatics, fools and ignoramuses, deeply suspicious of all those who have "found the answer" and on my bad days, downright rude.
  #3
Old 10-27-2012
svHyLyte's Avatar
Old as Dirt!
svHyLyte is on a distinguished road
Mark--
While I am not familiar with your particular engine, I am with Perkins in general and of those I have been acquainted with, Perkins rates their horsepower based upon a maximum RPM which can be maintained for a short period, a few minutes, but a maximum continuous service RPM that is typically in the range of 75% of rated horsepower RPM.
For example, our 4-108 is rated at 50hp at 4,000 RPM but that rate can only be maintained for a few minutes. Our maximum continuous service RPM is 3000 which, on our yacht with our prop gives us about 7.5 knots is moderate seas. We typically run the yacht at about 2500 RPM which gives us a good trade-off between speed and fuel consumption.
FWIW...
  #4
Old 10-27-2012
jrd22's Avatar
Courtney the Dancer
You'll need to know what the WOT (wide open throttle) rpm is supposed to be so you can determine if you are correctly propped/pitched. A Perkins dealer should be able to give you the correct max. rpm and the max. recommended cruising rpm (sorry, I'm not familiar with that engine). You should be able to run the engine at full throttle for 5 minutes or so if needed with no problem (if you have the right prop).
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
  #5
Old 10-29-2012
amarinesurveyor is on a distinguished road
The Perkins Perama M-30 engine puts out 29 hp at 3,600 rpm, that is your maximum rpm. Usually you can run diesels at 75 - 80% of maximum rpm all day long. That would be 2,700 to 2900 rpm. You should also be able to run at full throttle for short periods if everything is right (cooling system, clean prop, clean bottom, etc.).
Brian
  #6
Old 10-29-2012
caberg's Avatar
caberg is on a distinguished road
My Yanmar hits a spot at around 2500 rpm where it just feels right. That's not very scientific--and I agree you should know your numbers--but ultimately I think you will find that your engine has a sweet spot where it likes to run.
  #7
Old 10-29-2012
TQA's Avatar
TQA TQA is offline
Bombay Explorer 44
TQA is on a distinguished road
The Perama is not a 'real' Perkins in that it is not one of the heavily built over engineered lumps of cast iron like the 4-108.
It was made by Ishikawajima Shibaura Machinery, Ltd, yup Japanese, and marinised by Perkins.
With almost any diesel the throttle position tells the governor what rpm to run the engine at. That could mean full fuel which usually gives a trace [ or more ] of dark smoke. I avoid running my engine at full fuel if I can because that is max load on the engine.
  #8
Old 10-29-2012
MarkSF is on a distinguished road
Am I the only one who runs the engine at the one rpm setting where everything in the boat stops rattling? That's 2100 in my boat.
jrd22 likes this.
Bristol 31.1
  #9
Old 10-29-2012
SloopJonB's Avatar
Even with a one lung Yanmar I experienced the opposite - there was one rpm where everything quivered - the lifelines were a blur. If yours is shaking pretty well all the time you should check your mounts, shaft alignment and so forth - it sounds like something is wrong.
  #10
Old 10-29-2012
Hartley18's Avatar
Termite Fodder
Hartley18 will become famous soon enough Hartley18 will become famous soon enough
Unlike petrol engines, diesels (all diesels) are designed to be run under a decent load and relatively high rpms - even WOT - for long periods of time.
Long periods at idle/light load glazes the bore.
"Only two sailors in my experience never ran aground: one never left port and the other was an atrocious liar.." - Don Bamford
You may post attachments
You may edit your posts
Decertified candidates last push for signatures - WMBF NewsReader News Feeds 0 07-16-2012 04:00 PM
Push Pull Steering billbone Gear & Maintenance 6 03-07-2012 07:49 PM
Will a 6HP inboard push my 4000# Quickstep? Quickstep192 General Discussion (sailing related) 8 07-26-2011 12:18 PM
An old way to travel getting a new push (The Star-Ledger) NewsReader News Feeds 0 04-09-2006 02:15 AM
SEO by vBSEO 3.6.1
