Go Back   SailNet Community > General Interest Forums > Gear & Maintenance > Diesel Engine Forum
Diesel Engine Forum This is a new forum dedicated to diesel engines and their applicable accessories.
  #1
Old 11-12-2012
Letrappes's Avatar
Letrappes is on a distinguished road
Perkins 4-108 Fuel Injector Pump Leak
I noticed the smell of diesel in my boat a few weekends back so I got shopping around. I found a house clamp on the diesel return line was broken so I replaced it. I ran the engine for a while and didn't see any leaks.
This weekend I ran the engine for a while and when I went below immediately smelled diesel again. I found what looked to be a few leaks around the fuel pump but due to access it took a while to figure out this was from the top of the pump around the throttle I believe.
I was reading around and it was suggested that this might be caused by a blocked return line so I pulled the line off and put a wire through it. Seemed like I hit a block once that I pushed through. I started the diesel and the line ran free and when I reconnected it to the tank it appeared that the fuel injector wasn't leaking as much.
So now I'm wondering about the difficulty and any problems involved in replacing the seals/gaskets on this hydraulic pump. Does anyone have some guidance on this?
  #2
Old 11-12-2012
Hartley18's Avatar
Termite Fodder
Hartley18 will become famous soon enough Hartley18 will become famous soon enough
Re: Perkins 4-108 Fuel Injector Pump Leak
Sounds like the injector pump needs an overhaul.
Pull it out (following the instructions in the Service Manual to the letter) and take it to your nearest fuel injection specialist.
"Only two sailors in my experience never ran aground: one never left port and the other was an atrocious liar.." - Don Bamford
  #3
Old 11-12-2012
svHyLyte's Avatar
Old as Dirt!
svHyLyte is on a distinguished road
An injector shouldn't be leaking at all. Regarding the Injection Pump, you might want to read through this thread: DIY Injection Pump Rebuild - Cruisers & Sailing Forums . Its a bit long but filled with information. Also, check your oil for level and particularly for evidence of fuel contamination.
FWIW...
  #4
Old 11-14-2012
HDChopper's Avatar
Needing Apehanger Helm
HDChopper is on a distinguished road
Exellent feedback & info HyLyte ! thanks bunches , as most boats I am looking at have pump problems !
Glad there not much different than tractors (of which I am familiar with ) .
There is no right way to do the wrong thing
  #5
Old 11-14-2012
Letrappes's Avatar
Auto correct on the phone is fun. I do not have a leaking fuel injector. The fuel injector pump is leaking out of the throttle from what I can tell. I read the instructions on how to fix it and found the correct o-rings as replacements for a few bucks and will be getting them in the mail soon. In going this fixes the problem. I can't wait to play contortionist this weekend...
  #6
Old 11-14-2012
svHyLyte's Avatar
Old as Dirt!
Hopefully that is all it is. We thought so too, initially. Be sure to check your motor oil for fuel contamination.
FWIW...
  #7
Old 11-15-2012
Letrappes's Avatar
I'll check for diesel in my oil. If I have it I'll figure out how to get the girl injector pump out and have it rebuilt local.
  #8
Old 11-15-2012
Capnblu's Avatar
Capnblu is on a distinguished road
Be very careful with your girl injector... might be something you want a professional to look at...
Why, why, why?
I Don't Know! I Don't Know!
  #9
Old 11-15-2012
svHyLyte's Avatar
Old as Dirt!
Frankly, I'd have the oil analyzed if you have any question at all. Once the seals go around the throttle shaft, they usually have also gone/are going around the drive shaft as well (as I discovered). And it seems that all of them go somewhere in the range of 3000 to 3300 hours.
As long as some lamo hasn't installed an over sized water heater under the head of the port quarter cabin berth, you can get to the pump through the inspection port there if you are something of a contortionist. You'll need an Allan wrench socket with a long extension to get to one bolt on the back-side of the pump. It's a real chore.
Good luck!
  #10
Old 11-15-2012
Letrappes's Avatar
I really should read my posts as my auto correct on the cell phone does fun things. I unfortunately do have the water heater right there in the port bunk area making access fun. I honestly have no clue as to the hours on my motor as until recently the hour meter was not working.
You may post attachments
You may edit your posts
Fuel Injector Pump leaking Axle2121 Gear & Maintenance 18 10-02-2012 03:55 PM
Fuel leak in injector pump RussT1950 Diesel Engine Forum 8 04-12-2010 07:28 PM
Perkins 4.154 / Bosch VE Injector haamad Diesel Engine Forum 0 06-17-2009 12:01 PM
Diesel injector pump tbhudson Gear & Maintenance 6 12-15-2008 11:21 AM
Faulty fuel injector pump or? Eleanna Gear & Maintenance 2 10-24-2006 10:19 PM
SEO by vBSEO 3.6.1
