Yanmar 2GM20 (J) Achieving Design RPM - SailNet Community
post #1 of 9 Old 06-06-2013 Thread Starter
New Member
I have a FP catamaran model (35') diesel powered with YANMAR 2GM20 (FC)s (via SD 20s). I have 16 X 12, 2-blade props and am only getting about 3,100 rpm at full throttle and the design max rpm for the engine is said to be 3,600. The 16 x 12 props were measured but were really 16 x 11s. They were re-pitched to 10s hoping to get close to the 3,600 but only saw a modest (50 rpm) increase. What would you suggest to achieve the design rpm?
Last edited by dclery; 06-06-2013 at 10:21 AM. Reason: Engine model suffix was incorrect/incomplete
dclery is offline
post #2 of 9 Old 06-06-2013
JimsCAL's Avatar
Re: Yanmar 2GM20 (J) Achieving Design RPM
If you are happy with the boat speed, I wouldn't do a thing.
JimsCAL is offline
post #3 of 9 Old 06-06-2013
Gary M's Avatar
I second that
Gary M is offline
post #4 of 9 Old 06-07-2013
Freedom 39
FarCry's Avatar
I third that.
If you are still determined to get more RPM, you might confirm that the throttle cable is providing the full range of motion. You could pull the cable off and have someone open the throttle up by hand to confirm it's not a cable adjustment issue.
FarCry is offline
post #5 of 9 Old 06-07-2013
no longer reading SailNet
Alex W's Avatar
Are you sure that the tach is accurate? Get a digital tach and check it.
I know that mine is way way off (2000rpm on the tach means my engine is turning around 2700rpm). I have a 2GM20F.
Alex W is offline
post #6 of 9 Old 06-08-2013
I second the idea of checking your tacho. If the 3100 rpm is accurate and if it is not showing signs of being over-loaded at full throttle, like blowing smoke and raw diesel out the exhaust, AND if you are happy with boat speed, accept it.
Much less than 3100 at full throttle would not be good for this engine long term.
With my displacement mono-hull, I find that although it will turn 3200 to 3300 RPM at WOT, boat speed does not improve enough to measure (maybe a quarter of a knot) above 2800 RPM, which is what I would expect. The engine seems to have a cruising 'sweet spot' at 2200 to 2300 RPM so that's where it spends most of its time. Boat speed is about 1.3 knots below maximum at that. I do run it up to high power for a few minutes every hour or so as Yanmar recommends.
arvicola-amphibius is offline
post #7 of 9 Old 06-08-2013
JimsCAL's Avatar
And keep in mind that 3600 RPM is the maximum rating on the GM series, only good for 1 hour. 3400 is the continuous RPM rating.
JimsCAL is offline
post #8 of 9 Old 06-19-2013
First String
I have a 2gm. Cant seam to get it above 2800rpms in gear. It likes to run ar 2100. It will not take gear above 900rpms. I think my tac is wrong? I cant prove it. I dont want to buy a dig tacometer just to test it. Cheep I guess. I do push it hard coming back to the dock each time out. Were I know its working hard. I see some smoke, but not bad... The prop I understand has a lot to do with it.
here is the prop on mine. it folds. not its the correct prop for the boat. It dont work in rev much at all
15DX9P2
ltgoshen is offline
post #9 of 9 Old 06-19-2013
First String
Correction to my last post, I just looked at the tag on my Yanmar.
it is a 2GM 13 with a continuous duty rating of 3400 rpms
Is this a regular engine? is there a 2gm 13?
[IMG] photo Yanmar.jpg[/IMG]
Yes I have cleaned it up and it will soon be repainted?
ltgoshen is offline
Help Need a Yanmar Expert 2GM20 Mauiwowie Diesel 18 08-18-2012 05:44 AM
Yanmar 2GM20 vs 2GM20(f) (What the F?) L124C Diesel 11 06-17-2011 04:08 PM
Yanmar 2GM20 BillQ Diesel 5 04-11-2011 09:56 PM
Yanmar YSM 12 Vs. 2GM20 Medusa28 Diesel 2 11-08-2010 12:20 PM
Priming a Yanmar 2GM20 DAGEAR Diesel 9 06-26-2010 12:05 AM
