Help! Injector Pump repair without timeframe, etc. - SailNet Community
 3Likes
post #1 of 11 Old 06-10-2013 Thread Starter
Glad I found Sailnet
Bene505's Avatar
Need help with this one. My Perkin's (Lucas) injector pump started dripping out of a weep hole. So I removed it and took it to a neighboring diesel repair shop that the marina manager recommended.
They are quoting me 1800 to get a rebuilt one, then 250 minimum to re-install it on the boat. It will take 6 days to get a rebuilt one made and delivered from North or South Carolina. (I assume mine is used as the replacement core after the fact.)
The local place says they can't guarantee that they be able to put it into the boat in the days after the injector pump gets in. Time is a bit critical due to family expectations.
The place in NC or SC says that since this is marine, there can be no returns so the local place wants the full price up front, not just a deposit. Not sure what that means or why. My only guess is that perhaps there is another reason why diesel was coming out the weep hole, like a blocked line or something.
Does anyone have any experience with similar issues? Does everything seem on the up and up? I have what's basically a tractor engine, I'm thinking something may be amiss.
Regards,
Brad
Great minds discuss ideas;
Average minds discuss events;
Small minds discuss people.
The best minds discuss sailing (and a little bit of politics). I don't know why. It's a mystery!
Bene505 is offline
post #2 of 11 Old 06-10-2013
the pointy end is the bow
erps's Avatar
Re: Help! Injector Pump repair without timeframe, etc.
Oh man! I'd put it back on with an absorbent bilge cloth wrapped around it to get me though the family deal and then call up NorthLand Diesel Service in Bellingham WA and get a quote from them. It sounds like you're getting ripped off. Weep holes are there for a reason. There's a seal that's leaking and the engine manufacture would rather the diesel leak out than leak into your oil pan and thin the oil out.
Both JRD22 and I have had them do work for us and I used to use them in the old days when I had a truck repair business. They treated me right.
Faster and MedSailor like this.
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
erps is offline
post #3 of 11 Old 06-11-2013
Tartan 27' owner
CalebD's Avatar
Brad,
You are probably very nearly correct when you say that your engine is a tractor engine. It is likely that your same engine block # is used in some heavy equipment.
I have had some luck finding Kubota tractor parts for Universal marine diesels at up to 1/10th the price of the equivalent "marine" version from standard "marine" merchants. Glow plugs for the Universal 5434 engine at Torreson: $89 a piece. At a tractor supply website: $9 a piece. The trick with cross referencing Universal engines (which use Kubota engine blocks) is to find out the tractor model # the same block is used in. The same may work for your Perkins diesel engine. Google: "Perkins 84 HP diesel" (or whatever HP your diesel is) and look for heavy equipment that may use a similar/or same HP engine. Follow it from there for parts for the same heavy equipment.
No sense wasting money but it might make you feel better to replace that pump with a reasonably priced new pump while you sort out repairing the old one.
For $1800 I can get a running Atomic 4 engine on Ebay/CL. That is just an insult to rebuild an injector pump for that price. I'm not suggesting you should repower your Benny 505 with a 30 HP max Atomic 4 but I hope you get my point.
Everybody has one:
CalebD is offline
post #4 of 11 Old 06-11-2013 Thread Starter
Bene505's Avatar
Really good to see opinions from others on this. Much appreciated.
I can probably get the injector pump back on, within a couple degrees of where it was, if I go that route.
Regards,
Brad
Bene505 is offline
post #5 of 11 Old 06-11-2013
T37Chef's Avatar
$1800 to rebuild the pump sounds way high. I spent about $450 to have one rebuilt a few years ago. I realize its not the same engine but still that seems extremely high to me?
Shawn
T37Chef is offline
post #6 of 11 Old 06-11-2013 Thread Starter
Bene505's Avatar
I should add that it's a 4 cylinder Perkins, made in 1996.
Is there any chance this is really a problem with a blocked return line?
Regards,
Brad
Bene505 is offline
post #7 of 11 Old 06-11-2013
erps's Avatar
I'm not familiar enough with that specific injector pump to know, but it would be easy enough to test by opening the fuel return line somewhere and running it into a coffee can while the motor is running to see if it stops the leak.
The inside of the injector pump has a cavity that is filled with low pressure fuel that surrounds the high pressure piston pumps that supply each injector with fuel. I would suspect that there is a seal between that low pressure cavity and the shaft that spins a cam of some sort and that's the source of the fuel leak. It's probably a $10 seal, but it's in a $200 dollar spot.
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
erps is offline
post #8 of 11 Old 06-11-2013
Tartan 27' owner
CalebD's Avatar
Regards,
Brad
Brad,
Is your 4 cyl. Perkins rated at 84HP?
I'd need the exact HP to try to cross reference it.
Everybody has one:
CalebD is offline
post #9 of 11 Old 06-11-2013 Thread Starter
Bene505's Avatar
Originally Posted by CalebD View Post
Brad,
Sorry Caleb. It's a 4.2xx can't remember the last part.
It's not the oringinal engine, near as I can tell, since it's a 1996 and the boat is a 2000.
We can check next time we're at the boat.
Based on the advice here, I'm putting the injector pump back on the engine for a bit.
Regards,
Brad
Bene505 is offline
post #10 of 11 Old 06-11-2013
When somebody says it is "Marine", "Red flag"? I would think the same injector pumps could be used in other applications?
Paul T
dabnis is offline
Help! Leaking Injector Pump Classic30 Diesel 87 03-31-2014 12:29 PM
Fuel Injector Pump leaking Axle2121 Gear & Maintenance 18 10-02-2012 03:55 PM
Fuel leak in injector pump RussT1950 Diesel 8 04-12-2010 07:28 PM
Diesel injector pump tbhudson Gear & Maintenance 6 12-15-2008 11:21 AM
Faulty fuel injector pump or? Eleanna Gear & Maintenance 2 10-24-2006 10:19 PM
