Aluminum tank fittings - SailNet Community
post #1 of 4 Old 06-18-2013 Thread Starter
I'm installing an aluminum diesel fuel tank and want to have the fittings that screw into the tank to be aluminum, e.g. elbows, suction tube fittings, bolts for cover plate and barbed hose fitting. Any ideas on a source?
Walt Elliott
Kingston WA
Puget Sound
Cal-29
Waltthesalt is online now
post #2 of 4 Old 06-18-2013
Courtney the Dancer
jrd22's Avatar
Re: Aluminum tank fittings
Here is a list of possibilities Walt. Good luck with the project.
Aluminum Pipe Fittings on ThomasNet.com
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is offline
post #3 of 4 Old 06-21-2013
Seņor Member
PorFin's Avatar
Walt,
No personal experience with the vendor, but in MaineSail's narrative on his diesel tank replacement he stated that he got his aluminum fittings from Luther's Welding in Bristol RI.
________
'85 BYB Vagabond 39
PorFin is offline
post #4 of 4 Old 06-22-2013 Thread Starter
Thanks for both. Luther's said they'd take care of me.
Walt Elliott
Kingston WA
Puget Sound
Cal-29
Holding tank fittings - how much clearance? smp Gear & Maintenance 6 03-22-2013 12:03 AM
Converting water tank to diesel tank - fittings? Zanshin Gear & Maintenance 5 09-15-2009 05:38 AM
What oating / sealant on diesel tank fittings Northeaster Gear & Maintenance 3 03-28-2008 06:44 AM
holding tank fittings.. groundhog Gear & Maintenance 10 06-27-2007 09:34 PM
Holding tank fittings branda Gear & Maintenance 1 03-21-2001 09:12 AM
