Universal M18 - runs in neutral dies in gear. - SailNet Community
post #1 of 7 Old 06-30-2013 Thread Starter
I'm new to diesels, spent 3 years developing a knowledge of atomic 4's then sandy sank my boat. This is a new boat for me bought it over the winter, Catalina 30 with a universal M18. Did a sea trial in December ran fine, when the boat was launched we brought her about 3 miles to where I keep her, after finishing my rigging projects and replacing lines, and getting the sails up when I went to take her for her inaugural sail she started oK but sticky throttle. When I put the boat in gear in idle the revs go way down and she dies. There is no throttle response when she is in gear. A friend suggested the fuel system, I replaced all fuel filteres, pumped out the tank and put in new fuel but same deal, runs fine in neutral but put it in gear, no throttle response and no apparent forward movement, thinking to attacking the transmission and maybe diving to see if the prop is clear. Any thoughts I'd appreciate it.
John Rolka
johnrolka is offline
The Following User Says Thank You to johnrolka For This Useful Post:
mm2187 (06-30-2013)
post #2 of 7 Old 06-30-2013
Re: Universal M18 - runs in neutral dies in gear.
When was the last time the boat was hauled and checked/surveyed/cleaned it's bottom? Suspect fowling of prop and thru hauls.
aa3jy is offline
post #3 of 7 Old 06-30-2013
If you pull the throttle or press the override, so that it does not engage the transmission, will it increase RPMs without dying?
Jeanneau 54DS
Minnewaska is offline
post #4 of 7 Old 06-30-2013 Thread Starter
She was out of the water for a year before I bought her, the only thru hull in question is cooling which when she runs she pumps water fine and stays in proper temp range. I was thinkng of diving to inspect the prop, cutlas which were fine before launch, I was able to spin the shaft at the transmission coupling easily. The throttle is initially sticky but she responds, she idles at around 800rpm out of gear I've run her up to 2200 rpm. Whats confusing me when she was launched I motored over here no problem, same when I took her out in December, so far I've changed the fuel, I thing Ive eliminated fuel contamination and clogged filters. It's not like the prop is fouled, I can spin that easily???
What in the world is going on???
Thanks for your thoughts
post #5 of 7 Old 06-30-2013
One of None
deniseO30's Avatar
something like weeds or line could let it spin by hand but with power, really bog down the engine. Just saying.. Just a week ago a tree trunk floated between my rudder and prop. So you just never know what lurks beneath...
My last project!
deniseO30 is offline
post #6 of 7 Old 07-01-2013
So she will run up to 2200 out of gear but not in gear. Has to be drive train, unless she isn't running properly up to 2200, ie smoking or straining or knocking, etc.
Have you inspected the transmission? Fluid? Does it have the right product? Some take motor oil, some take trans fluid. Wonder if it has the right stuff. Just a WAG.
Jeanneau 54DS
post #7 of 7 Old 07-01-2013
Stu Jackson's Avatar
Critical Upgrades has some fuel issues related to M25 (similar) engines, in addition to those items mentioned: CRITICAL UPGRADES - DO THESE OR ELSE!!!
It's three pages, please read them all, not all are engine related.
Good luck.
Stu Jackson, Catalina 34, 1986, M25 engine, Rocna 10 (22#), Maple Bay, BC, Canada
Stu Jackson is offline
Woman dies as sailboat runs aground south of Courtenay - Victoria Times Colonist NewsReader News Feeds 0 01-08-2013 02:10 AM
Vibration in gear - Universal 5424 MarkSF Diesel 0 11-12-2012 01:07 PM
Engine runs today--dies tomorrow sidsail Gear & Maintenance 7 09-27-2012 06:44 PM
Universal Diesel gear box lubrication H and E Gear & Maintenance 5 12-06-2011 06:43 AM
Sailing in gear or in neutral? palacegrand General Discussion (sailing related) 10 12-26-2004 03:15 AM
