Universal M20 overheats when in gear, not getting full power - SailNet Community
post #1 of 6 Old 07-04-2013 Thread Starter
Headed out of the marina in our Oday 30 this morning, and the diesel engine (M20. Universal) started to overheat when accelerating and we couldn't get full acceleration when in gear (but could in neutral). Raw water is coming in freely, exhaust looks good, filter had jelly fish, so we flushed it several times. Doesn't overheat in neutral at any RPM, only with load.
What should we check next?
Boxer gal is offline
post #2 of 6 Old 07-05-2013
Tartan 27' owner
CalebD's Avatar
Re: Universal M20 overheats when in gear, not getting full power
Lack of normal acceleration sounds like maybe your prop is a bit fouled.
As far as the overheating, if you have a heat exchanger (HX) hooked up to your engine's cooling system I'd try cleaning that out 1st. Also change the zinc in the HX (read this link).
Autopsy A Westerbeke / Universal Marine Heat Exchanger Photo Gallery by Compass Marine at pbase.com
Check the impeller on the water pump as well.
If your engine is raw water cooled you can suck a gallon of white vinegar into it and leave it overnight. This can help clean up the cooling passages in the engine block.
Everybody has one:
CalebD is offline
post #3 of 6 Old 07-05-2013
Excessive load on the engine. Prop, Prop shaft, or transmission.
desert rat is offline
post #4 of 6 Old 07-05-2013 Thread Starter
Dove under the boat and found 1/4" of buildup on the prop and shaft. Scraped it off and will try the motor again tomorrow morning. Will definitely look for different bottom paint for the prop next season.
Thank you for your suggestions, will report back.
post #5 of 6 Old 07-05-2013
Tartan 27' owner
CalebD's Avatar
It takes only a surprisingly little amount of growth on a 2 blade prop to foul it.
Everybody has one:
CalebD is offline
post #6 of 6 Old 07-05-2013
Wandering Aimlessly
PBzeer's Avatar
And if it sits for anytime at all, it will get buildup.
John
Ontario 32 - Aria
Free, is the heart, that lives not, in fear.
Full, is the spirit, that thinks not, of falling.
True, is the soul, that hesitates not, to give.
Alive, is the one, that believes, in love.
JCP
- Website & Blog
PBzeer is offline
Universal M18 - runs in neutral dies in gear. johnrolka Diesel 6 07-01-2013 09:47 AM
Vibration in gear - Universal 5424 MarkSF Diesel 0 11-12-2012 01:07 PM
Universal Diesel gear box lubrication H and E Gear & Maintenance 5 12-06-2011 06:43 AM
Tricky reverse gear on Universal 5424 CalebD Diesel 2 05-30-2011 07:36 PM
One thing that worries me, swimming in full gear merlin2375 General Discussion (sailing related) 12 06-03-2008 12:04 PM
