Yanmar 2qm15 smoking in gear - Page 4 - SailNet Community
 2Likes
post #31 of 41 Old 08-22-2013
Re: Yanmar 2qm15 smoking in gear
Pitch too much or growth on the blades? Even if the engine is too small for the boat, flat out shouldn't have excessive black smoke.Raw water cooled ? maybe doesn't come up to temp to burn the maximum squirt of fuel
Capt Len is online now
post #32 of 41 Old 08-23-2013 Thread Starter
CanadianNorth's Avatar
The previous owner claimed he had no issues. Many people mention incorrect pitch... But would pitch change on a prop ? I'm assuming this the original prop from 34 years ago.
___________________
High Hopes
1979 Glastron Spirit 28, Hull #28.
Twenty years from now you will be more disappointed by the things you didn't do than by the ones you did. So throw off your bowlines. Sail away from safe harbor. Catch the trade winds in your sails. Explore, Dream, Discover.
Mark Twain
CanadianNorth is offline
post #33 of 41 Old 08-23-2013
I would not change on its own, but why would you assume it was never replaced over 34 years? It's very common for owners, particularly those selling their boats, to buy whatever they can find. Or, whatever they can find the cheapest. Some don't even know what pitch is.
Jeanneau 54DS
Minnewaska is offline
post #34 of 41 Old 08-23-2013 Thread Starter
Very true.
However, I know the last two previous owners dating back 10 years or so and they say the prop wasn't changed
___________________
High Hopes
Mark Twain
post #35 of 41 Old 08-23-2013
Very true.
Fair enough, but leaves 24 unanswered years. I suppose you confirmed with both that there were no issues during their ownership?
Btw. Is your exhaust elbow clean? Can cause back pressure and smoking.
Jeanneau 54DS
post #36 of 41 Old 08-26-2013 Thread Starter
The exaust elbow is clean, i assume,but is also not original. I had it custom made this summer (because I couldn't get an original part). It is very close to the diameter of the original.
___________________
High Hopes
Mark Twain
post #37 of 41 Old 08-26-2013
The engineering of an elbow may be more significant than it appears. How it bends, the diameter of the port and how water is introduced contribute to backpressure, which can cause smoking. Just something to think about.
Jeanneau 54DS
post #38 of 41 Old 08-26-2013 Thread Starter
Very true. The problems with the engine preceed the new elbow, that said it might be making things worse.
___________________
High Hopes
Mark Twain
post #39 of 41 Old 09-23-2013 Thread Starter
A little update for those following.
I pulled the injectors with the intention of testing the spray pattern. Long story short, I was unable to test them, but I did clean them up. There was a significant coating of carbon on them. I actually scraped it off the injectors.
To my surprise, the engine is running much better.
Now, I get no black smoke (previously I would always get some black smoke, and when I would go past about 1/2 throttle, or 1700ish rpms, I would get billows of black smoke and no power).
There was no smoke at all, and the engine started easily. The engine rpms did not drop when she went in gear, and she was able to rev up to 2500 rpms and give 6 knots.
Very surprising.
While not cured (past 2500rpms I get white smoke), there is definitely a significant improvement from before. Reflecting back, the carbon built up quickly over the 20-30 hours the engine was run this summer.... so I know there is still a problem somewhere in the system..
Thanks to all those who gave me advice.... and I think I'll keep some of that injector cleaner in my tank from now on.
fryewe likes this.
___________________
High Hopes
Mark Twain
post #40 of 41 Old 09-24-2013
repair it all
Did the previous owner change the prop? Seems from symptoms prop may be too aggressive for motor? Check the pitch and diameter of prop...
rustyballast is offline
2QM15 Yanmar weephee Gear & Maintenance 5 04-06-2013 08:15 PM
Yanmar 2QM15 sundownersc Diesel 11 02-09-2012 09:21 AM
Yanmar 2QM15 repairtime Gear & Maintenance 7 12-09-2011 04:40 AM
Smoking Yanmar DeanStrong Diesel 6 07-20-2011 05:51 PM
Yanmar smoking out rear marinesniper Gear & Maintenance 5 07-26-2008 07:05 AM
