M25 what is this and where does the hose go? - Page 2 - SailNet Community
post #11 of 15 Old 07-09-2013 Thread Starter
SSBN506's Avatar
Re: M25 what is this and where does the hose go?
Originally Posted by Stu Jackson View Post
On our M25, we simply routed the breather hose down to a peanut butter jar, drilled a hole for the hose and then a bunch more smaller ones to vent it. Any oil drops into the jar with full atmospheric pressure all around. Simple.
that is what I was thinking of doing. Simple and I wont be dripping oil on the engine that is then burning off like now. A lot simpler than tapping a hole in the air box also.
SSBN506 is offline
post #12 of 15 Old 07-09-2013
sailing soon
mark2gmtrans's Avatar
Send a message via Yahoo to mark2gmtrans
One more thing, if you guys are seeing a liquid oil discharge, not just the little tiny amount of aerosol vapor oil discharge, then you have an issue somewhere in your engine. There should be just a very small amount, barely visible, of smoke like vapor coming out of the tube, more than that is an indicator of positive pressure in the crankcase, which is, as I stated above, a problem. I recommend that you use the fuel and oil products for diesel engines that help them run cleaner, and I can highly recommend the Lucas oil treatment that goes in your engine oil. This stuff really does work, and it keeps the oil viscosity up where it should be at all operating temps, and does not make the oil thick like peanut butter when it is cold. This helps protect your valve guides and seals, rings, and cylinder walls, and your bottom end bearings, and all of those things are kind of necessary to have a good running long lasting engine.
These little engines will truly last longer than your boat if you take care of them, but if you do not, they will make good anchors if you melt them down.
It is good to learn from your mistakes, but much better to learn from the mistakes of others...
mark2gmtrans is offline
post #13 of 15 Old 07-09-2013
sailing soon
Are you getting a lot of oil out of the tube now?
post #14 of 15 Old 07-09-2013 Thread Starter
SSBN506's Avatar
I cant tell, if you look at the picture of my engine you can se that part of the engine is a bit darker then the rest. The jar option would tell me if it is leaking to much I assume.
http://vision-networking.ca/m25.jpg
SSBN506 is offline
post #15 of 15 Old 07-09-2013
sailing soon
I would say you have a point there, put the jar on it, but make sure the lid has one other hole in it, to let air out so that it is not pressured up with the heat from the oil vapor. Let us know how much you actually are getting in there, my guess is that it is not much, the engine you have in the photos is not a dripping mess as far as I can tell. When you have the engine running and it leaves puddles like a puppy then you know you have a big problem, a tiny amount of oil vapor over a long period of time will discolor the paint, so you probably have no big problems.
Quick-connect hose fittings for bilge hose? cghubbell Gear & Maintenance 1 06-03-2010 03:45 PM
washdown hose davidpm Gear & Maintenance 7 08-22-2009 09:21 PM
Air hose question wmiii Gear & Maintenance 15 10-04-2007 02:12 AM
Spa flex PVC hose for sanitation hose TrojanSailor Gear & Maintenance 6 07-22-2007 08:51 PM
d hose Shelgail Island Packet 7 08-14-2006 01:30 PM
