Yanmar 1 gm issue - SailNet Community
post #1 of 3 Old 07-09-2013 Thread Starter
caberg's Avatar
Yanmar 1 gm issue
I have a Yanmar 1 gm. I start it up in neutral and it starts just fine. If it's been a week or so, I need to hold the starter for maybe 10 seconds and then it catches. If it's been running that day, it catches within 1-2 seconds. Idles great, sounds good, doesn't smoke.
The problem I started having a week ago is when I put it in gear. When idling, I can throttle up and down and the RPMs go up and down as they should (idles at around 650 and tops out at about 3200). Then, I put it in forward, and then throttle up a bit. The RPMs start going up and then drop all the way back down to idle speed (~650 RPMs). After about 30 seconds, the RPMs come back up to match the amount of throttle I'm giving, and then the engine/throttle is in perfect sync for however long I run it for.
My intuition tells me it's not a fouled prop, because after about 30 seconds it runs exactly like it should.
What should I check? Obviously, my concern is to catch an issue before it becomes a bigger one. Right now, this doesn't affect the use of the engine.
caberg is offline
post #2 of 3 Old 07-11-2013
JimsCAL's Avatar
Re: Yanmar 1 gm issue
Sounds like you may be getting a bit of air into the fuel system when it sits for a few days. First place to look is the filter, especially if you just changed it.
JimsCAL is offline
post #3 of 3 Old 07-12-2013 Thread Starter
caberg's Avatar
Thanks, Jim. I'll have to figure out how to diagnose air in the fuel system.
caberg is offline
Throttle up issue Yanmar 6CX(M)-ETC Littleelvisdan Diesel 3 01-02-2013 10:19 AM
Yanmar 2GM20F RPM issue cspaniel Diesel 11 05-20-2012 04:01 PM
Yanmar 2GM20F RPM issue cspaniel Diesel 0 07-02-2011 08:14 PM
Yanmar 2GM injection pump issue? kcford Diesel 10 05-03-2011 10:03 PM
Another Yanmar Low RMP Issue rk6johnson Diesel 2 12-01-2010 01:42 PM
