M4-30 won't start....Help! - SailNet Community
post #1 of 5 Old 07-10-2013 Thread Starter
This is installed in a 1970 Bristol35. Was running fine until a few days ago. When I push the glow plug and start button, it makes a single click. Subsequent attempts may or may not be rewarded with the"click". I've veified that the batteries are fully charged and took off all cables, cleaned the connections and reinstalled (2 batteries). There's 12 volts at the engine connector as well as the instrument connector. The low oil pressure light, bilge blower, glow plug and fuses (2) are good with 12 volts both sides of fuse.
I accidently grounded the positive wire (from battery to bolt under starter) and a great shower of sparks was the result, so I'm assuming that the starter is recieving power as well. I can't think of anything else but a bad starter solenoid or the starter itself. Is there a way to test the solenoid or starter motor? I would appreciate any insight in troubleshooting this anyone may have. The engine is a 1989-ish Universal M4-30 diesel 4 cyl. with less than 240hours on it
salty sam is offline
post #2 of 5 Old 07-10-2013
BarryL's Avatar
Re: M4-30 won't start....Help!
Hey,
Before you do anything else, make sure the ground is good. I had a similar problem last year with a friend's boat. He even changed the starter but the problem stuck around. It turns out that the main ground was bad. So there was plenty of power and good wiring, but no way for the starter to get the amps needed. Cleaning and re-installing the main ground lug on the engine block solved all the problems.
Good luck,
Barry
Barry Lenoble
Deep Blue C, 2002 C&C 110
Mt. Sinai, NY
BarryL is online now
post #3 of 5 Old 07-10-2013 Thread Starter
Thanks, I believe you may be right as it acts like the batteries are dead or really low. I'll go back and check the ground. This is the cable from the neg battery post to a bolt on the engine block, correct?
Kevin
post #4 of 5 Old 07-10-2013
BarryL's Avatar
Correct, that's the one.
On the boat I referred to the connection looked ok but when the mechanic (I had used up all my skill by that time) loosened the bolt the lug just came apart because it was all corroded.
Barry
Kevin
Barry Lenoble
Mt. Sinai, NY
post #5 of 5 Old 07-11-2013
Sailor
Gladrags1's Avatar
There also might be a relay in the wiring from the start button that went bad. It's one that is activated by the switch but then actually makes the connection for electricity to the starter. Not sure where to find it on your engine but a mechanic can replace it in minutes. Not an expensive job.
Tod
Mandolin
Bayfield 36
Sailing out of Rock Creek, Chesapeake Bay
Gladrags1 is online now
Don't even know where to start hamsterdam herSailNet 4 11-21-2012 08:56 AM
where to start looking? GrumpyPawPaw Electronics 1 08-10-2011 12:48 PM
I don't even know where to start. MariaDelMar Introduce Yourself 6 11-05-2009 08:47 AM
where to start??? BarnacleBuntons Introduce Yourself 7 08-24-2009 04:21 PM
How do I start? pilot2sailor Learning to Sail 4 10-03-2003 12:17 PM
