Yanmar 2QM15: strange overheating incident - Page 2 - SailNet Community
 3Likes
post #11 of 20 Old 07-13-2013
Re: Yanmar 2QM15: strange overheating incident
I had a raw water cooled Volvo in a boat we owned a number of years ago. The thermostat is in the salt. It got funky like you describe and was very easy to replace. Do it yourself job....cannot hurt to try it.
capecodda is offline
post #12 of 20 Old 07-14-2013 Thread Starter
That's my next step.
1981 Spirit 28 "Bonnie Lass"
Bremerton, Washington
Rusty123 is offline
post #13 of 20 Old 07-16-2013 Thread Starter
I haven't pulled the thermostat yet, but have some new symptoms to post, for the sake of anyone who may read this thread in the future.
Took the boat out for the afternoon, and ran the engine for a couple hours. Like the last time, the temperature was stable, but about 10 degrees higher than normal (running about 135F, vice 125F).
I pulled the raw water strainer basket, and it looked clean at first glance, but when I looked closer, there was what appeared to be a small jellyfish in the bottom. But I think what it really was was an accumulation of bio-slime. I scrubbed out the basket thoroughly and replaced it. After starting engine again, temps seemed to drop a bit, but time was running short, and I wasn't able to perform a thorough test.
I'm still planning to pull, and perhaps replace the thermostat as part of an upcoming maintenance evolution.
Rusty123 is offline
post #14 of 20 Old 07-16-2013
Neosec's Avatar
There's no rule that says it has to be one thing. Maybe a weak thermostat AND a slightly clogged intake AND a missing impeller blade...
Neosec is offline
post #15 of 20 Old 08-04-2013 Thread Starter
I haven't had an opportunity to pull the t-stat or head yet, but I went out for a few hours this afternoon (first time in a couple weeks). I kept a close eye on the temperature, and as soon as it started to creep up (which took about 45 minutes), I throttled down and was able to maintain temps that way. But I also noticed that I've lost about a knot off hull speed, and the engine seems to be working harder than usual. I also noticed some black smoke at full throttle, which I haven't noticed before.
Suspecting bottom growth, I called a local diver when I got home. He had just cleaned my boat in early May, and the paint was in good shape, so he doesn't think that excessive bottom growth is the problem. But he does strongly suspect that barnacles on my prop are the culprit, since my prop is unpainted, and boats in my marina experience heavy barnacle growth in May/June (he lives aboard in the same marina). Cleaning is scheduled for later this week.
So back to the original post: might barnacle growth on my prop be contributing to my mild overheating condition?
Rusty123 is offline
post #16 of 20 Old 08-08-2013
..and your results?
aa3jy is offline
post #17 of 20 Old 08-08-2013
bljones's Avatar
Okay i gotta get this out there- you have an engine that is becoming increasingly unreliable, repeatedly overheating, and instead of taking fifteen minutes to pull the thermostat and fix the problem, or at least knock one suspect off the troubleshooting list, you went sailing?
The problem is not going to get cheaper to fix, the longer you ignore it. Even running slower as an overheating workaround is not doing the engine any favours.
It's 5 o'clock somewhere:
bljones is offline
post #18 of 20 Old 08-08-2013 Thread Starter
Originally Posted by aa3jy View Post
..and your results?
Parts came in, so I swapped out the T-stat and impeller. Also topped off oil. Hull and prop was cleaned a couple days ago.
Took her out for a spin, and everything seems normal. Temps are good, speed was good, engine rpm back to normal.
Not sure which (or all) of these was the main contributor, but problem seems to be resolved.
Thermostat was rust stained and spattered with small particles of gunk, but no major obstruction. I ordered a gallon of rydlyme for a flush though.
Thanks for the suggestions.
bljones likes this.
Rusty123 is offline
post #19 of 20 Old 08-29-2013 Thread Starter
I pulled the mixing elbow - it's surprisingly plugged up. But the exhaust manifold looks good. I've read that this can contribute to overheating (as well as other symptoms), so I'm hopeful that the new elbow will help.
Rusty123 is offline
post #20 of 20 Old 09-08-2013 Thread Starter
Rydlyme flush: check
New thermostat: check
New exhaust elbow: check
New exhaust hose: check
New raw water discharge hose: check
New raw water impeller: check
Result: 5 hour run at 80% max RPM, cool as a cucumber.
Faster and fryewe like this.
Rusty123 is offline
Yanmar 2QM15 Overheating Problem Summer Magic Diesel 18 06-18-2013 10:40 AM
2QM15 Yanmar weephee Gear & Maintenance 5 04-06-2013 08:15 PM
Yanmar 2QM15 Overheating at Idle... backcreeksailor Gear & Maintenance 35 08-16-2012 10:58 AM
Yanmar 2GM or 2QM15...? marinesniper Gear & Maintenance 20 03-10-2012 12:47 AM
Yanmar 2QM15 repairtime Gear & Maintenance 7 12-09-2011 04:40 AM
