Yanmar 2QM15: strange overheating incident - SailNet Community
 3Likes
post #1 of 20 Old 07-10-2013 Thread Starter
I've had my (1981) boat for about 6 months, and the engine (which was a concern of mine, due to uncertain history) has run flawlessly until last week.
I took some friends out for the afternoon, motoring out of the marina and for about 30 minutes to find some wind. Shut down the engine and sailed for about an hour. Kids started getting cranky, so I pulled down the sails and started up the motor.
After idling in neutral for about 1 minute, I get a high temperature alarm, so I shut the engine down. Guage reads about 160F (it's raw water cooled, so normal temp is about 120F). Waited about 10 minutes, but temp guage doesn't drop, so I tentatively restart to get some cooling flow. Although water appears to be coming out the exhaust, the temp stays high and alarm still sounding.
So I shut it down again and start checking stuff. Oil level is good, raw water strainer is clean (but we're drifting through a heavy moss/algea/seaweed current line). I can't find any obvious problems, so I start it one more time, and this time, the temperature rapidly drops, and everything returns to normal. Motored back home without incident.
I've had it out once since then, with no issues.
Any idea what might have happened? My guess is that a got a piece of debris on the hull strainer, which eventually dropped off on its own. Planning to change out the impeller soon, just in case that was somehow related.
(Incidentally, is there some law of nature that says stuff only goes wrong when you've got guests on board?)
Rusty123 is offline
post #2 of 20 Old 07-10-2013
Tartan 27' owner
CalebD's Avatar
Re: Yanmar 2QM15: strange overheating incident
Could easily have been a plastic bag that got sucked over your raw water input and later it drifted away.
Stuff always goes wrong when you are trying to impress somebody.
Everybody has one:
CalebD is offline
post #3 of 20 Old 07-10-2013
Old enough to know better
Just wait till you have a date on board!
Congrats on the boat. Yanmar's are great motors.
Sent from my ADR6425LVW using Tapatalk 4 Beta
1976 C&C 33
Project boat, lots of work to be done!
miatapaul is offline
post #4 of 20 Old 07-11-2013
marcusc130's Avatar
If you had good water flow when the temp was high, I would say you might have a sensor problem. I'd take a look a the thermostat connections, and maybe pull the thermostat and see if its all gunked up and not opening.
marcusc130 is offline
post #5 of 20 Old 07-11-2013
JimsCAL's Avatar
Yes, could be thermostat or problem with the alarm circuit. Hard to believe it would overheat in only 1 minute of idling.
JimsCAL is offline
post #6 of 20 Old 07-11-2013 Thread Starter
I thought about that too. Difficult to tell for sure, so I'm going to take a wait and see approach.
Rusty123 is offline
post #7 of 20 Old 07-11-2013 Thread Starter
I thought about that too. Difficult to tell for sure, so I'm going to take a wait and see approach. When I do my annual engine maintenance this year, I'll probably change out the T-stat just in case.
Rusty123 is offline
post #8 of 20 Old 07-11-2013
MarioG's Avatar
I had the same problem last fall with my 2QM20 last fall in Hobe sound Fl. I had water flow and a clean raw water strainer. After looking things over 3 times and pulling a few hands full of hair out I finally pulled the hose from the seacock to find some sea grass trapped. it wasn't enough to stop water flow but still made engine over-heat.
Endeavour E-32 "Samara"
I am the Capt of my ship but sometimes I think I had more fun just being the cabin boy.
MarioG is offline
post #9 of 20 Old 07-11-2013
Freedom 39
FarCry's Avatar
Have you ever checked or replaced the engine zincs? When they deteriorate they can send "chunks" into the raw water cooling system.
FarCry is offline
post #10 of 20 Old 07-13-2013 Thread Starter
Went out today, ran the engine hard for about three hours. Temp was stable, but about 10F higher than normal. I'm suspicious of the thermostat.
1981 Spirit 28 "Bonnie Lass"
Bremerton, Washington
Rusty123 is offline
Yanmar 2QM15 Overheating Problem Summer Magic Diesel 18 06-18-2013 11:40 AM
2QM15 Yanmar weephee Gear & Maintenance 5 04-06-2013 09:15 PM
Yanmar 2QM15 Overheating at Idle... backcreeksailor Gear & Maintenance 35 08-16-2012 11:58 AM
Yanmar 2GM or 2QM15...? marinesniper Gear & Maintenance 20 03-10-2012 01:47 AM
Yanmar 2QM15 repairtime Gear & Maintenance 7 12-09-2011 05:40 AM
