Have an engine you want to convert to "marine" - SailNet Community
Advertise Here
Go Back   SailNet Community > On Board > Gear & Maintenance > Engines > Diesel
Like Tree1Likes
  • 1 Post By deniseO30
Old 07-16-2013
deniseO30's Avatar
Oday30!
I really have too much time on my hands!
I've been researching things on Kubota engines, transmissions, water manifolds etc.
Basically it seems if you DIY the marine conversion of an engine.. say out of a tractor or from a vendor.
The Needs;
Base engine
Marine manifold (some have Heat Ex built in)
Heat exchanger
Raw water pump. (and a way to drive it)
Panel and gauges,
Wire harness ( or make one)
Bell housing and adapter for the transmission.
Water lift muffler and gooseneck
Transmission,
Shaft
Prop
Engine mounts
Shaft log
Seal or stuffing box.
coupling,
flywheel and plate.
anti-siphon device,
various hoses, tubes, connectors, adaptors,
Fuel system,
Electric fuel lift pump (or mechanical)
Hardware,
Raw water strainer (should be large)
Add "sweat equity"
All this above and more.. is it worth it to save $2-4,000?
I'm not going to do this, or ever attempt it, but It does seem to be more popular in other countries.
Denise, Bristol PA, Oday 30. On Tidal Delaware River, Anchor Yacht Club. New Website!
My boat is sold!
Reply With Quote Quick reply to this message Share with Facebook
  #2
Old 07-16-2013
Minnewaska will become famous soon enough Minnewaska will become famous soon enough
Re: Have an engine you want to convert to "marine"
If that is what you save from buying new and then do not have a manufacturer to go after, if there is a problem, I would pass. Not sure what the base cost is that the 2-4 is being added to, however. I'm also guessing that sweat equity gets frustrating as some point, when something just doesn't go as planned.
Jeanneau 54DS
  #3
Old 07-16-2013
T37Chef's Avatar
T37Chef will become famous soon enough
And I would have thought you would be busy as a bee with this heat and owning a HVAC Company
Cheers,
Shawn & the crew of S/V Windgeist
1982 Tartan 37 CB - Hull #358
  #4
Old 07-16-2013
deniseO30's Avatar
Oday30!
No it's all pretty much gone Shawn, I'm hitting the big 65 next week
Now it's gone from "I had the money and not the time"; to "I have the time and not the money"
But the refridge in my boat works very well!
jimgo likes this.
My boat is sold!
  #5
Old 07-16-2013
jimgo's Avatar
Asleep at the wheel
jimgo is on a distinguished road
Happy Birthday a few days early!
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
You may post attachments
You may edit your posts
"Seacock" vs. "ballcock" or "ball valve?" SEMIJim Gear & Maintenance 18 09-02-2013 05:31 PM
Convert 2" Exhaust hose to 2 3/8" n8kraft Diesel 7 08-23-2012 06:06 PM
Eemax "marine/rv" Tankless Water Heater - EX2412M and insuarnce? SanDiegoChip Gear & Maintenance 10 07-28-2010 10:48 AM
Fwd: Marine Products Clearance. GPS units, Chart Kits, "chips," NewsReader Mass Bay Sailors 0 07-10-2007 01:15 PM
C270 Main Sail "stack Pack", Quick Cover", "lazy Bag" Install randy22556 Catalina 1 02-28-2007 11:53 AM
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
SEO by vBSEO 3.6.1
The SailNet.com store is owned and operated by a company independent of the SailNet.com forum. You are now leaving the SailNet forum. Click OK to continue or Cancel to return to the SailNet forum.
