Yanmar YSM 8 Fuel problem - SailNet Community
post #1 of 5 Old 07-16-2013 Thread Starter
Lostmt's Avatar
My Yanmar didn't have a fuel filter water separator so I added one. Reason being I didn't know the condition of the inside of the fuel tank. I added a Donaldson fuel filter.
After many hours of pumping I couldn't get the air out of the system. Today I remover the Donaldson and the system pumped up right away and my motor ran like a top.
OK something is blocking the filter. Took it a part and everything looks good. Filled the filter with fuel. Nothing couldn't get a drop to flow.
Do I need to get an electric fuel pump to push the fuel through the filter. Its a long spin off on type. If so on the electric fuel pump should it be a low pressure pump? I couldn't find any information in the manual about how much pressure the manual pump puts out.
Thanks for your thoughts
Lostmt is offline
post #2 of 5 Old 07-17-2013 Thread Starter
Lostmt's Avatar
Re: Yanmar YSM 8 Fuel problem
I found the solution to my fuel problem.
Lostmt is offline
post #3 of 5 Old 07-17-2013
deltaten's Avatar
Send a message via Yahoo to deltaten
Inquiring minds wanna know! What *was* the solution to the problem?
S/V Chrysalis
'80 Watkins 27
North East, MD
deltaten is offline
post #4 of 5 Old 07-18-2013 Thread Starter
Lostmt's Avatar
Sent you an email.
Process of elimination. $99.00 filter bad. $11.00 filter from NAPA worked like a top.
Smooth water never makes a good sailor.
S/V Miss Sadie
1978 Watkins 27
Middle Texas Coast
Lostmt is offline
post #5 of 5 Old 07-19-2013 Thread Starter
Lostmt's Avatar
After a nice phone visit with the manufacturer of the filter in question I found out that they are not for marine use. Also it requires more fuel pressure our small sailboat engines than we can produce without installing an electric fuel pump.
The reason they are not for marine use is because the drain plug is plastic and this does not meet Coast Guard regulation. If I had the filter install and the CG inspected me I could get written up.
S/V Miss Sadie
1978 Watkins 27
Middle Texas Coast
Lostmt is offline
yanmar YSE8 Fuel problem Adele-H Diesel 14 08-07-2013 11:10 PM
Yanmar Fuel Problem? Julie303 Diesel 5 10-05-2012 11:52 PM
Fuel Fill Problem SailorAm General Discussion (sailing related) 5 12-12-2011 07:12 PM
yanmar 2qm15 fuel problem pfirth Diesel 11 05-11-2011 12:23 PM
Yanmar 2qm15 fuel problem pfirth Diesel 10 04-09-2011 01:20 AM
