Incoming water hoses univeral 5411? - SailNet Community
post #1 of 6 Old 07-18-2013 Thread Starter
I would like to replace the incoming water hoses that go from the incoming water valve to the impeller with hardwall hoses. When I looked @ the hoses that are currently on the boat they are 5/8 ID. When I pull the hose off of the barb it is 1/2 in. Does anyone know what size hard wall hose I should have? My guess is that I need 1/2 in hard wall hoses but, maybe the barbed fittings are not correct?
dickauge is offline
post #2 of 6 Old 07-18-2013
Re: Incoming water hoses univeral 5411?
It would be better to have the hose a tight fit on the barb, in case a clamp fails. When I put new hoses on my 5424 I think I had to change the barbed fittings. Just be careful to get proper bronze ones, not brass. That goes for any other fitting in contact with salt water.
Good practice is also to double clamp, but only if the barb is long enough. Better to have one clamp than a second one that is trying to pull the hose off the barb because it's only half on.
MarkSF is offline
post #3 of 6 Old 07-18-2013
Learning the HARD way...
eherlihy's Avatar
Simple; " hoses go on " barbs...
On my Universal M25 (the follow on to the 5411) the intake is a 3/4" through hull with a 5/8" barb on it. The 5/8" hose goes to a strainer with a 5/8" barb on the intake, and a " barb on the out. From there, a " hose goes to the raw water pump, which has two " barbs. Then there is a hose that goes to the heat exchanger, which also has a " barb on the input, and another on the output. From here is a hose that runs from the H/X to a " vented loop, and then to the exhaust elbow, which also has a " barb fitting.
I hope this helps
eherlihy is offline
post #4 of 6 Old 07-19-2013
JimsCAL's Avatar
Had a 5411 on my previous boat. All hoses were 1/2 inch. And the replacement for the 5411 was the M15, not the M25.
JimsCAL is offline
post #5 of 6 Old 07-19-2013
I just replaced all the hoses on my Universal M2-12. They were all 5/8. I had trouble finding a good reinforced hose and ended up using a steel reinforced hose that is normally used for hydraulic application. Not sure that was the correct thing to do so I will watch them for signs of decay.
H and E is offline
post #6 of 6 Old 07-19-2013
eherlihy's Avatar
Yep, you're right. The 5411 was the predecessor of the M15. The 5421 was the predecessor of the M25.
Anyway, do not use a 5/8" hose on a " barb (as the PO of my boat did).
eherlihy is offline
water leaking in oil - Universal Diesel 5411 stef9 Gear & Maintenance 21 11-24-2013 01:55 AM
Universal 5411 Water Pump dbruce85 Diesel 1 05-05-2011 10:41 PM
Universal 5411 and water sep filter imiloa Diesel 2 02-17-2011 10:25 PM
5411 water pump BudRICKETT Diesel 4 10-15-2009 11:18 AM
