Yanmar 1GM10 won't start. - Page 2 - SailNet Community
 1Likes
post #11 of 16 Old 07-22-2013
bljones's Avatar
Re: Yanmar 1GM10 won't start.
if fuel is good, intake and exhaust elbow are clear, then I am with arvicola- your fuel shut off cable is hanging up.
lawsonmitchell likes this.
It's 5 o'clock somewhere:
bljones is offline
post #12 of 16 Old 07-22-2013 Thread Starter
Fuel shut-off is stuck in shut-off position or the cable has come adrift from the arm on the FCU Valves stuck open - maybe due to slight mis-rig of the decompression lever - a 'love tap' with a rubber hammer on the rocker cover could be the fix for this, otherwise pull the rocker cover and see if the valves are moving through full range as you crank it.
Now that sounds like a solid concept. I'll try to get out to the boat and give it a try.
Thanks,
Lawson
1972 Dufour Arpege Galadriel
Prior owner on Pearson 39-2 Periwinkle
Boca Ciega Yacht Club, Gulfport, Florida
lawsonmitchell is offline
post #13 of 16 Old 07-23-2013
Any idea the cost to rebuild a single cylinder Yanmar like this? Sorry, this doesn't answer your question but I am considering buying a Hunter 30 with one of these engines and I suspect a rebuild may be in order. TIA. Hank
hank9752 is offline
post #14 of 16 Old 07-27-2013
Quite simply, if timing compression and fuel are all ok it has to fire, physics says that. Working injectors and injector pump with ample fuel and compression makes a bang. If it hits on starting fluid sprayed in the intake, you are most likely not getting fuel in the cylinder. Possibly low compression, but a low possibility. Drain fuel system on the engine, purge the fuel lines to the engine, check and change filters, replace fuel with new clear diesel charge system and bleed completely. Unless you have a timing or compression problem it should at least hit.
wescarroll is offline
post #15 of 16 Old 08-08-2013 Thread Starter
GRIM news. It's compression. Shite.
post #16 of 16 Old 08-08-2013
Over Hill Sailing Club
smurphny's Avatar
Maybe the valves? Try a valve adjustment before you remove the head. It's possible that one of the valves is fouled up with carbon deposits or even burned and can't seat. Pulling the head will tell you if it's valves or rings. In any case, re-ringing one of these shouldn't cost a lot, maybe $200 for rings and gaskets if you do the work yourself. For a one banger, maybe just order a new piston with rings and replace the bearings while you're at it. You'd essentially have a new engine.
Looks like it ran on ether just because ether doesn't need compression to ignite.
smurphny is offline
Yanmar 1GM10 won't start Sometimesbrilliant Gear & Maintenance 16 08-01-2014 06:00 PM
Loss of power on a Yanmar 1GM10? lawsonmitchell Diesel 7 07-31-2014 09:42 PM
Yanmar 1GM10 and racor fuel filter. SVDistantStar Diesel 7 01-25-2014 03:46 AM
Yanmar 1GM10 Thermostat and Temp Sending Unit karluk Diesel 5 07-01-2012 05:54 AM
Yanmar 1GM10 Overheating BayLAzr Diesel 8 07-29-2011 02:40 PM
