Perkins 4.108 Air Cleaner / Silencer - SailNet Community
post #1 of 7 Old 07-22-2013 Thread Starter
Dear All,
I cannot seem to find exactly what I am looking for so I thought a picture might help. One is the cover of the manual and the second describes what I am looking for. Any ideas?
Thanks,
Chris
ccolton is offline
post #2 of 7 Old 07-22-2013
Seņor Member
PorFin's Avatar
Re: Perkins 4.108 Air Cleaner / Silencer
Chris,
That's a new topic for me -- I've never seen your references.
That said, it looks like it would be a pretty simple thing to fabricate (note I said simple, and not necessarily inexpensive...)
Basically, you're looking at installing a run of air induction ducting from your desired intake point to your engine. Depending on your engine install, this could be incredibly easy or frustratingly difficult.
I'll be following this thread to see how it goes...
ATB,
PF
________
'85 BYB Vagabond 39
PorFin is offline
post #3 of 7 Old 07-23-2013 Thread Starter
Hi Porfin,
Thanks for the reply.
I guess the real question I have is this: what's inside the air filter/silencer? Is it just a container that has a filter in it?
If so, and I will show my ignorance here, why would mounting it away from the engine quiet the engine?
Thanks,
Chris
ccolton is offline
post #4 of 7 Old 07-23-2013
Old as Dirt!
svHyLyte's Avatar
Originally Posted by ccolton View Post
Dear All,
Thanks,
Chris
You might want to look into the Walker AirStep. These are quite costly however and really aren't necessary although they supposedly quiet the intake of the 4-108.
svHyLyte is offline
post #5 of 7 Old 07-23-2013
Seņor Member
PorFin's Avatar
Chris,
I'm not sure about the design of the filter/silencer you've found.
The original design for the 4.108M air "cleaner" is nothing more than a screen with openings big enough to stop things about the size of wood chips -- not exactly what you'd expect to see if you're concerned about dirt getting into the intake. It also does a very poor job of attenuating any noise you've got coming from the intake manifold.
A good filter (like a K&N) would reduce the noise coming from the intake.
A good reason to remote the air intake is to draw cooler air directly into the engine. If your engine install is anything like mine, it's in a relatively cramped area that warms up pretty quickly. Cooler air is better for compression/combustion.
________
'85 BYB Vagabond 39
PorFin is offline
post #6 of 7 Old 07-24-2013 Thread Starter
Dear Porfin,
Thank you.
A good point about the cooler air and, yes, like you, I have a cramped engine area. Almost enough to make me a power-boater...No, not enough.
If I hear from anyone else, I will write back.
Chris
ccolton is offline
post #7 of 7 Old 07-24-2013 Thread Starter
Dear svHyLyte,
Yes, I am familiar with both the Walker AirSep and with its price. It's a good recommendation and I may opt for it but I want to see if I can figure out exactly what this induction air filter/silencer is first.
Chris
ccolton is offline
Noisy exhaust - silencer ageing? MarkSF Diesel 2 08-15-2012 10:15 PM
Upholstery Cleaner? HBBurlington General Discussion (sailing related) 14 05-18-2011 02:39 PM
Yanmar Intake Silencer vtsailor11 Gear & Maintenance 4 05-26-2009 03:35 PM
mast cleaner lgsailor19 Gear & Maintenance 3 04-30-2005 02:39 PM
