anaerobic sealant? - SailNet Community
 1Likes
  • 1 Post By ECS-IB30
post #1 of 3 Old 07-25-2013 Thread Starter
anaerobic sealant?
I am about to reinstall my injector pump which had a clog. The mechanic that fixed it for me recommended using an anaerobic sealant where the machined flange sits on the block.
The Volvo workshop manual does not say to do this. I understand why the mechanic recommended this but am nervous to go against the workshop manual.
Any thoughts, comments, advice?
Thanks in advance.
birdlives is offline
post #2 of 3 Old 07-25-2013
Islander Yacht Fan
ECS-IB30's Avatar
I've used the permatex aviation sealant for many yrs in racing conditions far more extreme than the md7a I recently put back in my boat...its all I use now for everything...never had a failure related to its use.
http://www.permatex.com/products/product-categories/gasketing/gasket-sealants/permatex--aviation-form-a-gasket--no--3-sealant-liquid-detail
I am not connected to the company in any way
kd3pc likes this.
ECS-IB30 is offline
post #3 of 3 Old 07-27-2013
Re: anaerobic sealant?
Loctite 518 Gasket Eliminator is just the thing for your job. It is intended to be used between metal flanges or plates.
http://www.useloctite.com/filephotos...ions_Guide.pdf
This assumes that the parts do not have to be repositioned after assembly.
If so then Hylomar might be what you are looking for.
http://www.hylomar-usa.com/_resource..._Univ_Data.pdf
Not affiliated with either, but I've been using them for years.
guyfromiowa is offline
Which sealant? copacabana Gear & Maintenance 18 09-27-2010 04:53 PM
Sealant for below the waterline... sailhog Gear & Maintenance 4 03-01-2010 05:41 PM
which sealant to use LookingForCruiser Gear & Maintenance 5 07-09-2009 08:18 AM
Sealant recommendations sailingtime Gear & Maintenance 4 03-26-2009 01:36 PM
What Sealant To Use? 1970Columbia34 Gear & Maintenance 9 11-17-2006 07:44 PM
