Loosing rims - SailNet Community
post #1 of 5 Old 07-29-2013 Thread Starter
nodders's Avatar
Loosing rims
I am in the middle of a cruise and twice we have had some trouble with the engine suddenly loosing a couple hundred rpm. I have a yanmar 2 gm. The first time the problem corrected itself after 5 minutes or so. This time were we're in tight and very windy quarters so headed in to a bay to get anchored nice we lost power out in the wind.
I am suspecting a fuel problem, but being fairly new to the boat am not overly familiar with its systems. I replaced the fuel filter about 150 hrs ago, an placed the filter in the water separator about 50 hours ago. It called for a 10 micron but the shop only had 2 micron and they said that would be fine. Not sure if that could be a part of the problem? All parts of the fuel system seem tight.
Any emergency suggestions?
Sorry just saw the title and it should read RPMs!! My iPad changed the spelling!
I am not really from Toronto
nodders is offline
post #2 of 5 Old 07-29-2013
kd3pc's Avatar
Re: Loosing rims
10 microns....
and I change mine as needed, but way sooner than 150 hours. Usually at every oil change - 35-45 hours, or as needed when things burp.
water separator filter as needed, but if Drain more than a 1/3 cup of water at a time, it goes as well.
stay away from 2 micron except the last filter before the injector pump, the little tiny one.
kd3pc is online now
post #3 of 5 Old 07-30-2013
Dirt Free
boatpoker's Avatar
Re: Loosing rims
Sure sounds like fuel starvation. Change primary & secondary filters and carry spares. Cut the old filters open and see whats inside.
The hysterical laughter you hear as you drive a way in your"new" boat ..... is the seller.
boatpoker is online now
post #4 of 5 Old 07-30-2013
chucklesR's Avatar
Re: Loosing rims
If the filters are clean by which I mean blocked up as opposed to off white it's not them.
You are changing them often enough to where unless you are loading bad fuel it should be fine.
I suspect air has gotten into the system, especially as you say you are unfamiliar with the system. Check your manual and do a very thorough bleed all the way to the injectors.
Check the air filter as well.
chucklesR is offline
post #5 of 5 Old 08-06-2013 Thread Starter
nodders's Avatar
Re: Loosing rims
By way of a quick update, I checked the new filter in the fuel/water separator and it looked like i had been pulled from a mud puddle! I noticed a fair amount of crud in the bottom of the bowl and suspect it got all mixed up when the boat was in motion and clogged the filter. I cleaned out the bowl thoroughly, replaced the filter and the problem was solved. Motored for 12 hours without so much as sputter!
nodders is offline
Loosing power Universal M25XP Bump Gear & Maintenance 8 07-07-2013 02:45 PM
loosing the driple$$ seal and getting stuffing box deniseO30 Gear & Maintenance 39 11-28-2007 11:08 AM
Loosing sleep over this deniseO30 Living Aboard 63 11-09-2007 11:48 AM
Accelerating the learning curve crewing and loosing the fear of heeling over! Lancer28 Learning to Sail 7 10-17-2007 01:27 PM
shroud turnbuckle keep loosing eric97217 Gear & Maintenance 3 03-25-2004 01:38 AM
