Yanmar 2qm15 gear lever problem - SailNet Community
post #1 of 1 Old 08-01-2013 Thread Starter
Hi,
I recently reinstalled My 2qm15 Yanmar engine during my boat restoration project. This model has the KBW10 gearbox and I'm having real problems shifting into Neutral after selecting Forward or Reverse. This problem is definitely with the shift lever which is located on the side of the gearbox and is operated by a Morse 33c cable.
The gearbox clicks into gear ok but is very, very stiff when trying to select neutral. When the shift lever is disconnected from the cable, the gears can be easily selected by hand but it's very tight trying to get back into Neutral. When the cable is connected to the shift lever it is even worse. it's really so stiff I am worried about breaking the handle on the Morse control lever.
My throttle/gear control is the Teleflex MV-2 Morse type which I fully serviced and rejuvenated before re-installing. I also replaced the original morse cables with brand new ones and there are no tight bends so I know the cables are not contributing to the problem.
Before I installed the engine I serviced the geabox by flushing it with kerosene and oil and have since filled it with the correct new oil as specified by Yanmar.
Does anyone know what I can do to solve this problem, please?
redx.
redx is offline
Yanmar 2qm15 smoking in gear CanadianNorth Diesel 40 09-26-2013 03:48 PM
Yanmar 2QM15 Decompression Lever? Aprisa SJ 28 Gear & Maintenance 5 06-23-2012 11:27 PM
yanmar 2qm15 fuel problem pfirth Diesel 11 05-11-2011 01:23 PM
Yanmar 2qm15 fuel problem pfirth Diesel 10 04-09-2011 02:20 AM
Yanmar 2QM15 Problem shipley Gear & Maintenance 5 05-18-2001 10:17 PM
