Universal m430...Simple Question. - SailNet Community
post #1 of 5 Old 08-04-2013 Thread Starter
this is a very simple question if you happen to be looking at a universal m4 30. I simply need to know what is the length from the end of the dipstick to the top of the stopper. My stopper has come lose and unbelievibly there is no mark or discoloration hinting as to where it was....obviously that leaves me without the possibility measuring my oil accuratly. Any help would be much appreciated.
Wayward Drifter is offline
post #2 of 5 Old 08-04-2013
fryewe's Avatar
Re: Universal m430...Simple Question.
I don't have an M4-30.
But if I had a question about my dipstick I would change the oil - making sure I get as much oil as possible out of the engine - then fill with the specified volume of oil.
After filling with oil:
- insert the dipstick and check the level on it...repeating as needed until the dipstick is wet to the full level...using care to note the relationship between the stick and the engine entry hole at each checking.
- and then permanently mark the stick at the point where the stick and entry hole are in the proper relationship. You will never have to worry about the little cap moving again.
The web makes everywhere the same place. - Fred Reed, from "Fred on Everything"
fryewe is offline
post #3 of 5 Old 08-04-2013 Thread Starter
That is a good logical reply. In fact it was the first thing that I did. But after doing it I was convinced that I hadn't gotten all of the old well out. And I'm not sure that I actually can. So since I am unable to Be sure, And we all know the dangers of overfilling a diesel with oil. I'm just looking for somebody That can give me that measurement... Thank you again
post #4 of 5 Old 08-09-2013
JimsCAL's Avatar
You could order a new dipstick. Probably a bit pricy from Universal, but cheaper from a Kubota dealer if you know the model.
JimsCAL is offline
post #5 of 5 Old 08-09-2013
Stu Jackson's Avatar
I agree. A new dipstick would seem the most consistent way to go. I would if it was my boat.
This may help identifying your equivalent Kubota engine.
Universal 5432 & M40 engine information
If there si ANY question about the integrity of the dipstick "plug" just get a new one. I bought one for our M25 from a Universal dealer (tres expensive) in 1999 for well less than $50.
Good luck.
Stu Jackson, Catalina 34, 1986, M25 engine, Rocna 10 (22#), Maple Bay, BC, Canada
Stu Jackson is offline
Universal M430 Injector Pump Springs jenry Gear & Maintenance 1 09-30-2012 08:30 PM
Simple genoa question Tonyhibbett General Discussion (sailing related) 18 04-08-2012 11:57 AM
Simple question, but still a question:keel repair eckcn17 Gear & Maintenance 9 03-16-2011 11:01 AM
Simple question Johnqboater Cruising & Liveaboard Forum 9 02-11-2011 12:00 PM
a simple zinc question... sailhog Gear & Maintenance 53 07-13-2007 10:30 PM
