2YM15 pressure in overflow container - SailNet Community
post #1 of 6 Old 08-05-2013 Thread Starter
Last few weeks the plastic top has been blown off of the overflow container on the boat and dumping anti-freeze into the bilge, about a cup/round trip. Don't motor much: 5 minutes out and 5 minutes in usually.
Any ideas? I see references in the Yanmar help section to faulty heat exchange caps and faulty thermostats, but not in response to this exact issue.
BTW, per the owner's manual the antifreeze in the overflow container is supposed to cycle back into the heat exchanger as the engine cools. How does it do that when the only line into the container drops in from the top.
Thanks...
blueblisteringbarnacles is offline
post #2 of 6 Old 08-05-2013
fryewe's Avatar
Re: 2YM15 pressure in overflow container
The only time I have seen that happen was when I blew a head gasket and the blown area of the gasket allowed exhaust gases to enter the cooling system.
Good luck.
The web makes everywhere the same place. - Fred Reed, from "Fred on Everything"
fryewe is offline
post #3 of 6 Old 08-05-2013
Omatako's Avatar
Thanks...
The correct name for the overflow container is actually expansion bottle/tank. The pipe that drops into the top should reach down to about 2/3rds or more of the way down inside the tank.
The pressure cap on the heat exchanger is designed to allow coolant (which is not compressible) to go somewhere when it expands. It goes into the expansion tank. When the engine cools the pressure cap allows the resultant vacuum to draw coolant back from the expansion tank. Consequently an amount of coolant continually flows back and forth.
If the pipe does not reach down far enough, the cooling of the engine will cause the system to draw air into to cooling system. The next time the engine gets warm, the air will expand more than the coolant and a greater volume of coolant will be pushed out because there is more expansion happening. So check that the end of the pipe is never hanging in air, it must always be in coolant.
If you fill the expansion tank so that there is inadequate space to accommodate the coolant that is oscillating back and forth, it will overflow into your bilge (coincidentally about a cup-full ). But it should do that only once. If you then top it up when it appears to be about half full, it will do it again and again until you stop topping it up.
If it overflows even after you have not topped it up, then the chances are there is excessive pressure building in the cooling system and that points to a leaking head gasket. Alternately you need to try and get all of the air out of the cooling system.
So the short story is: Try not topping up the expansion tank, keep it about half full, make sure the end of the pipe is always in the coolant and observe the result. React accordingly.
Edit: Incidentally, the purpose of a pressure cap is to create a constant pressure in the closed-circuit cooling system because the coolant can then go to a much higher temperature before it boils (in excess of 100 degrees C). If the cap is dodgy and is not maintaining pressure, there is a chance that the engine could boil off coolant.
My first synopsis is the most likely but this edit just demonstrates that it is not the only scenario.
Arthur C. Clarke
Omatako is offline
The Following User Says Thank You to Omatako For This Useful Post:
blueblisteringbarnacles (08-06-2013)
post #4 of 6 Old 08-06-2013 Thread Starter
Very helpful, thanks!
post #5 of 6 Old 06-14-2015
I have a yanmar 2GM20F and after motoring for a short time (10-15 minutes) the cap to the coolant expansion tank blew off and filled up above the "full line" it boiled over and I lost some coolant into the bilge.
also water stopped flowing out of the exhaust. I've checked the impeller and it's fine. I also replaced the mixing elbows a month ago.
is it ok to restart the engine to get the coolant back into the engine?
dbw_kairos is offline
post #6 of 6 Old 06-15-2015
JimsCAL's Avatar
Please refrain from posting the same question in multiple places.
JimsCAL is offline
coolant overflow or leak? spec2 Diesel 6 08-16-2011 02:58 AM
yanmar 2YM15 oil agriff Diesel 2 06-21-2011 02:05 PM
Stuck water heater overflow valve imiloa Gear & Maintenance 3 01-15-2010 03:31 PM
Holding tank overflow into bilge? countrygent5201 Gear & Maintenance 4 12-02-2009 12:01 PM
Fule overflow rate Yofy Gear & Maintenance 8 02-24-2008 02:49 AM
