2GM20F RESERVE coolant tank - SailNet Community
post #1 of 7 Old 08-06-2013 Thread Starter
First String
I just purchased a 2GM20F and It is fresh water cooled? It did not come with a tank for the coolant? Can i use any type tank or does it have to be the O.E.M 128397-44500 TANK ASSY, RESERVE Tank that the parts manual calls for?
thanks for the help.
ltgoshen is offline
post #2 of 7 Old 08-06-2013
Irrationally Exuberant
Re: 2GM20F RESERVE coolant tank
I don't remember there being anything special about that plastic coolant tank. I would think any tank from a car would do.
Tom K
2000 Beneteau 331
Northern Chesapeake Bay
arf145 is offline
post #3 of 7 Old 08-07-2013 Thread Starter
First String
Thanks.
ltgoshen is offline
post #4 of 7 Old 08-10-2013
Omatako's Avatar
The normal plastic expansion tanks that are used on cars are not intended to hold any pressure. Your cooling system should have a pressure cap on the exhaust manifold heat exchanger.
If you're going to use an automotive non-pressure expansion bottle, (and there is no reason why you shouldn't) make sure the pressure cap on the engine is in good shape. Also, maybe just have a look at my response in the following thread, it may be relevant.
http://www.sailnet.com/forums/diesel...container.html
Arthur C. Clarke
Omatako is offline
post #5 of 7 Old 08-12-2013 Thread Starter
First String
Thanks this makes good since.
ltgoshen is offline
post #6 of 7 Old 08-12-2013
Sea Sprite 23 #110 (20)
mad_machine's Avatar
bigger the better?
Art Haberland
In the end all that matters is how fully you loved, how gently you lived, and how gracefully you let go of things that did not belong to you -Buddha
mad_machine is offline
post #7 of 7 Old 08-13-2013
Omatako's Avatar
Originally Posted by mad_machine View Post
bigger the better?
No real advantage in my view to bigger than necessary. All the bottle has to do is accommodate the amount of expansion in coolant from cold engine to hot engine and that's generally not much, probably less than a litre.
Arthur C. Clarke
Omatako is offline
Isolating house and reserve batteries on Beneteau 373 dworob Electrical Systems 3 05-06-2011 08:36 AM
Where to put engine coolant expansion tank preservedkillick Gear & Maintenance 12 11-03-2008 04:17 AM
Crusing Budget (reserve) RandyonR3 Cruising & Liveaboard Forum 1 11-03-2007 02:52 PM
Coronado 35 Ebay No Reserve sailhawk Boat Review and Purchase Forum 1 04-23-2004 08:07 PM
6 Volt, reserve vs weight jbanta Gear & Maintenance 5 05-07-2003 09:16 PM
