Deisel Engine Day Tank. - SailNet Community
 1Likes
post #1 of 16 Old 08-09-2013 Thread Starter
Considering a day tank on advice received.
What are the advantages of having a day tank and what are the disadvantages of having a day tank.
piclarke is offline
post #2 of 16 Old 08-10-2013
Daniel - Norsea 27
Rhapsody-NS27's Avatar
Re: Deisel Engine Day Tank.
I found out my main tank has a leak after the boat got into the water. So that I could still use the boat, I ordered a 3 gal tank to put in line with my engine until I haul out the next time. I am still able to use the boat and the engine seems to like the cleaner fuel. The only thing I had to do was add a fuel return line to the tank.
You can see what I did at my blog. Link in my signature below.
Daniel
1981 Nor'sea 27,
“Who is staring at the sea is already sailing a little.”
-Paul Carvel
Rhapsody-NS27 is offline
The Following User Says Thank You to Rhapsody-NS27 For This Useful Post:
piclarke (08-10-2013)
post #3 of 16 Old 08-10-2013
Stu Jackson's Avatar
Advantages:
Two sources of fuel
If installed higher than the engine, the day tank could provide fuel to the engine without a separate electric lift pump or if the lift pump failed
Disadvantages
Requires more fittings/couplings all prone to failure
Needs fuel MANAGEMENT to assure that return line goes to the right place and doesn't overfill an unused tank
Could require more valving for proper management purposes
Very small day tanks have the possibility of heated return fuel increasing the temperature of stored fuel - hot fuel is not good
Stu Jackson, Catalina 34, 1986, M25 engine, Rocna 10 (22#), Maple Bay, BC, Canada
Stu Jackson is offline
post #4 of 16 Old 08-10-2013 Thread Starter
Originally Posted by Stu Jackson View Post
Advantages:
Two sources of fuel
Disadvantages
Thanks.
The vessel I was on, the day tank was installed above with a eye filling tube
so as over filling avoided. Had a powerful lifting pump to fill the tank with a non return valve and gravity feed to the engine. The day tank was refuelled each time it got low which was every morning approx. Engine room was monitored every hour during running included using heat sensor hand gun for temperature readings any where on the engine fuel lines, gear box, and any where else plus fuel tank.
Commercial fisherman I have spoken to, say they are a must in the tropics, did not think to ask why. So I guess the answer is the engine is not reliant on a fuel pump feeding the engine during running.
Marine engineer stated on non day tank above installation the standard engine lift pump is sucking the fuel from the ships fuel tank which can cause or will cause problems over time. With a day tank the pump is installed so that it is pushing the fuel to the day tank avoiding problems according to him. A pump pushing is 3 times more powerful pushing than sucking, I was told.
piclarke is offline
post #5 of 16 Old 08-10-2013 Thread Starter
Thanks
piclarke is offline
post #6 of 16 Old 08-11-2013
Originally Posted by piclarke View Post
...according to him. A pump pushing is 3 times more powerful pushing than sucking, I was told.
Utter nonsense.
post #7 of 16 Old 08-14-2013
Utter nonsense.
Actually this is quite correct and most definately not nonsense. Pumps have a problem sucking up and if you take the time to check manufacturers specifications on almost all types of pumps, the greater the head on the suction side, the lower the output of the pump. This includes bilge pumps.
As far as pumps used to get diesel from the fuel tank to the engine, they all push fuel out better than they suck. This is why an electric pump is always fitted as close to the fuel tank as possible when there is a long run between the tank and the engine. This will get the engine the fuel it needs to run properly.
Stanley,
Marine Diesel Engine Vendor
NCboatrx is offline
post #8 of 16 Old 08-14-2013
aeventyr60's Avatar
I have been operating in the tropics for 10+ years, with a Perkins 4108. No problems with my system. Gravity feed will not work here.
Fuel pump is engine mounted and driven so it is going to suck.
I had a fuel tank in the bow and the engine fuel pumped sucked it back(20') just fine.
As my diesel mechanic told me "that pump will suck the chrome off a bumper hitch"
Don't over think and over engineer your fuel system. Out here we call it another "stupid cruiser trick". KISS
christian.hess likes this.
"Your dreams minus your doubts equals your net worth"
Life is a short journey, filled with emptiness and pain. Get all the sailing and booty you can.
aeventyr60 is offline
post #9 of 16 Old 01-15-2014 Thread Starter
Can't understand that because the vessel I sailed on we where sailing in the Tropics and the COMMERCIAL FISHING PERSON WAS OPERATING in PNG WATERS and thats Tropical.
piclarke is offline
post #10 of 16 Old 01-16-2014
denverd0n's Avatar
Some explanation as to why would be nice. Sure, at the equator the force of gravity is about 0.3% less than it is at the poles, but somehow I don't think that's enough difference to make a gravity feed system unworkable.
denverd0n is offline
Deisel Engine Training Anyone? East Coast Bene505 General Discussion (sailing related) 14 02-25-2009 12:35 PM
Deisel Engine Question Voyager2007 Gear & Maintenance 8 12-09-2008 06:06 AM
Where to put engine coolant expansion tank preservedkillick Gear & Maintenance 12 11-03-2008 04:17 AM
Gravity Running Tank for Engine capecodphyllis Gear & Maintenance 11 01-18-2007 10:29 AM
12 HP Deisel engine...want a little more power marinesniper Gear & Maintenance 16 08-10-2006 06:03 PM
