Muir 800 Windlass (frozen shaft) - SailNet Community
Advertise Here
Go Back   SailNet Community > On Board > Gear & Maintenance > Engines > Diesel
Old 08-12-2013
DixeyJulie is on a distinguished road
Send a message via Skype™ to DixeyJulie
I am trying to disassemble the windlass (1991); it had not been maintained, and needs a new motor, but the shaft is stuck? I removed all the bolts and
the bolt into that is in the bottom of the shaft that goes through the gear casing. There seems to be no retainer spring anywhere, so I guess that has never been there. Any ideas?:
Reply With Quote Quick reply to this message Share with Facebook
You may post attachments
You may edit your posts
Frozen rudder shaft Hinterhoeller 28 rbyham Gear & Maintenance 195 03-07-2013 02:03 PM
Muir v Lofran chall03 Gear & Maintenance 6 05-01-2012 01:38 AM
muir manual pc37howard Pacific Seacraft 4 08-15-2011 09:16 AM
windlass muir herculeshm1200 pc37howard Pacific Seacraft 3 02-22-2010 04:31 PM
Manual windlass with frozen clutch sailiraq Gear & Maintenance 6 01-09-2008 11:09 PM
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
SEO by vBSEO 3.6.1
The SailNet.com store is owned and operated by a company independent of the SailNet.com forum. You are now leaving the SailNet forum. Click OK to continue or Cancel to return to the SailNet forum.
