Temperature gauge install - SailNet Community
post #1 of 5 Old 08-14-2013 Thread Starter
LJP
New to a Universal 5411 and a Catalina 27. Concerned with over heating the engine. The instrument panel does not have temperature gauge and don't believe a sensor for the engine. What is the process to install the needed equipment. More concerned with the engine piece sensor and placement. I can handle the wiring to the instrument panel. Panel does not have space, but I would remove the fuel tank gauge. Sailing on a lake with a 15 gallon diesel tank not too concerned with running out of fuel. Would appreciate any help
LJP is offline
post #2 of 5 Old 08-15-2013
Re: Temperature gauge install
Maybe something here?
Google
Paul T
dabnis is offline
post #3 of 5 Old 08-19-2013
JimsCAL's Avatar
I had a 5411 on my previous boat. Had a temp gauge but no alarm! You can buy a generic gauge and sender from Defender, West Marine or many other suppliers. The sender needs to be installed in the cooling water loop, probably using a tee. Note there is one electrical connection on the sender, the circuit is completed through the ground. Thus the sender body must be grounded.
JimsCAL is online now
post #4 of 5 Old 08-19-2013
Catalina Direct have (very expensive!) kit to add a temperature switch and alarm.
MarkSF is offline
post #5 of 5 Old 08-19-2013 Thread Starter
LJP
Thanks to All,
Returned this weekend to the marina. I do have a temp gauge. I replaced the thermostat.
Engine never got above 150 degrees. Therefore, no exhaust water. Checked all the hoses, impeller and mixing-T all clear. Is that normal to have no exhaust water under 150 degrees?
LJP is offline
temperature gauge wmjr Pacific Seacraft 0 06-10-2013 01:09 PM
Stuffing box temperature Ajay73 Gear & Maintenance 12 07-16-2012 01:51 AM
Temperature Classic30 General Discussion (sailing related) 40 08-15-2011 12:06 AM
C400 Batt install and Inv/CHg install Cruisingdad Catalina 1 08-01-2007 01:02 PM
Teak Oil and Temperature labatt Gear & Maintenance 4 02-03-2007 05:09 PM
