removing timing gear cover - SailNet Community
post #1 of 3 Old 08-15-2013 Thread Starter
trantor12020's Avatar
I have a leak at timing gear cover gasket. I want to remove it to replace the gasket. The service manual (thanks to aa3jy) said to remove injector pump first, from what I understand, it is not necessary to remove injector pump. Anyone any suggest or comment?
I have a Yanmar 2GM20F engine.
Ken
2002 Hunter 326, SV Millennium 2
1999 Macgregor 26X, SV Millennium
trantor12020 is offline
post #2 of 3 Old 08-18-2013 Thread Starter
Re: removing timing gear cover
I've removed the timing gear cover without removing the fuel pump, just slacken of the 4 nuts to lift it alittle off the cams. Found the leaking portion of the gasket. oops unable to upload photos.
Ken
post #3 of 3 Old 08-19-2013 Thread Starter
Any suggestion how i should clear the rust from my crankshaft pulley? Its off the engine already.
Ken
Removing pawls and main gear on barient winch abrahamx Gear & Maintenance 13 08-13-2013 11:05 PM
Yanmar gear case cover removal telekitr Diesel 0 11-11-2011 07:18 AM
Cracked Timing Gear Cover Yanmar 1GM lans0012 Diesel 6 02-15-2011 05:59 PM
MD7A Volvo Penta Timing Gear shebobah Gear & Maintenance 5 10-27-2008 03:23 PM
Removing a Staysail Sail Cover mathislaw1 Gear & Maintenance 1 07-30-2007 12:51 PM
