anti siphon valve universal m25 - Page 2 - SailNet Community
post #11 of 19 Old 08-23-2013
JimsCAL's Avatar
Re: anti siphon valve universal m25
Originally Posted by Stu Jackson View Post
Jim, you're right in that it is an AIR check valve. Most people reading your post, me included, most likely thought you meant a check valve in the WATER line, which we agree does not and should not exist.
Sounds like we agree Stu. Just a question of terminology.
JimsCAL is online now
post #12 of 19 Old 08-23-2013 Thread Starter
I've removed everything and rest enn assuring me that the air or water circulating well. I'm a little skeptical that a cleaning pipes and valve gives a good result. I will test this weekend. Thank you again!
fastbreak is offline
post #13 of 19 Old 08-23-2013
Learning the HARD way...
eherlihy's Avatar
Look at this:
eherlihy is offline
post #14 of 19 Old 08-23-2013
eherlihy's Avatar
I had a nylon vented loop on my O'day 35 with an M25. I broke it, and have since installed a Forespar Marelon loop, but removed the duckbill, and retro-fitted the 3' long tube that goes well above the water line, and was originally on the nylon loop. I keep the duckbill - just in case.
eherlihy is offline
post #15 of 19 Old 08-23-2013
One of None
deniseO30's Avatar
all this reminds me of something that needs to be done on my new inverted loop for the engine... connect the vent side to a hose! if it goes bad It will be a bad day for sure LOL
My last project!
deniseO30 is offline
post #16 of 19 Old 08-23-2013
eherlihy's Avatar
Think of it as a power rinse for the engine compartment...
eherlihy is offline
post #17 of 19 Old 08-26-2013
Fresh water refugee
katsailor's Avatar
Thanks for the reminder, I will add it to my punchlist.
I learned the hard way this weekend after I finally splashed Shakti about why I was should not have forgotten to drill the shaft and set the set screw for the new motor coupling.
That and a couple hours stuck in the mud on my maiden voyage to the slip was an adventure.
Experience teaches us things we would rather not know.
S/V Shakti '81 Offshore Cat Ketch 33'
katsailor is offline
post #18 of 19 Old 08-27-2013 Thread Starter
I was skeptical but now I am confused! I cleaned the gasket and all rested up and I have no leak. Everything works as before. Thank you for the advice. Small additional question: Close up the water inlet valve of the engine whenever you stop the engine?:
post #19 of 19 Old 08-28-2013
Fresh water refugee
katsailor's Avatar
Some do, some don't. It's a hole in the boat that has the ability to fail. Whatever lets you sleep.
If you have a scoop type through hull fitting it is a good idea to close it when sailing so you do not hydro-lock the motor by forcing water into the engine through the exhaust system when under sail for an extended period of time.
Atomic 4s and anti-siphon valves ? tommays Atomic 4 2 08-04-2009 05:52 PM
Anti Siphon Valves PorFin Gear & Maintenance 2 09-19-2008 06:03 PM
Anti Siphon Valves pooch6641 Gear & Maintenance 1 04-24-2008 10:49 AM
Engine destroyed by anti-siphon valve jimfortuna Gear & Maintenance 19 01-14-2008 08:50 AM
Exhaust anti siphon jackytdunaway Gear & Maintenance 12 06-04-2007 05:51 PM
