"Help" 2GM20F Exhaust flang will not tighten - SailNet Community
post #1 of 13 Old 08-16-2013 Thread Starter
First String
I have tried i bet 10 time's to get the exhaust flang to tighten up? It will not tihten on both the top and bottom at the same time?
It is the male couplin coming out of the mixing elbow into the exhaust elbow. Does it get a nother coupling of some type?
God help... I'm at my witzzzz end. I dont want to take the exhaust elbow off the block. I dont have a steel gasket and cant look up parts for this engine? No parts manuls out there on line.
Again its the double threaded silver nut in the middle of the photo How do I get them to tighten at both ends at the same time?
ltgoshen is offline
post #2 of 13 Old 08-16-2013
Irrationally Exuberant
Re: "Help" 2GM20F Exhaust flang will not tighten
From your picture, you've already got all the parts off the block, no? I replaced the coupling and mixing elbow on a 2GM20F a few years ago. And if I recall correctly, you need to tighten the coupling onto one part and then spin that combination to tighten onto the other. You use a wrench on the middle of it to keep it from loosening off one end while tightening it to the other.
The short answer would have been, I don't think you can just tighten both at once--the threads are not reversed on the two ends of the coupling and each end needs a clockwise turn. Again, this is my recollection, recalled through the fog of war that surrounds all my boat repairs
Tom K
2000 Beneteau 331
Northern Chesapeake Bay
arf145 is offline
post #3 of 13 Old 08-16-2013
trantor12020's Avatar
One of the thread is Reverse. I think its the bottom one. By right you could turn the coupling in one direction and it will tighten both top and bottom. But its easier to do it on a bench vice so that you could make it tight and not leak.
Ken
2002 Hunter 326, SV Millennium 2
1999 Macgregor 26X, SV Millennium
trantor12020 is offline
post #4 of 13 Old 08-16-2013
BarryL's Avatar
Hey,
You can't.
First tighten the coupler into the elbow. I would use thread sealant. Then tighten the mixing elbow into the coupler, again with sealant. If, for some reason, you can't do that, you will need a union.
Good luck.
Barry
Barry Lenoble
Deep Blue C, 2002 C&C 110
Mt. Sinai, NY
BarryL is online now
post #5 of 13 Old 08-16-2013
Ditto on the sealant. Easier to get apart next time too.
Tom K
2000 Beneteau 331
arf145 is offline
post #6 of 13 Old 08-16-2013 Thread Starter
First String
Sorry, the photo is not mine. I just used it as an example. I do not have my exhaust elbow off the block. I do have the mixing elbow and the reverse coupling seperated. I will use pipe dope when connection mine.
Barry, I like your Idea I just dont know it I have the room in extra height?
ltgoshen is offline
post #7 of 13 Old 08-16-2013 Thread Starter
First String
Can you reuse the gasket?
ltgoshen is offline
post #8 of 13 Old 08-16-2013 Thread Starter
First String
I think I foun the part number...
128370-13201 yanmar gasket Non-Asb
ltgoshen is offline
post #9 of 13 Old 08-16-2013
I was able to do it with the exhaust part still on the engine. I had enough space to turn the mixing elbow with coupling to tighten onto exhaust.
Tom K
2000 Beneteau 331
arf145 is offline
post #10 of 13 Old 08-17-2013
Doing it in-situ will probably not be tight enough to prevent leaks.
Ken
"Seacock" vs. "ballcock" or "ball valve?" SEMIJim Gear & Maintenance 18 09-02-2013 05:31 PM
Convert 2" Exhaust hose to 2 3/8" n8kraft Diesel 7 08-23-2012 06:06 PM
VIDEO: Coast Guard Academy Welcomes "Blue Goose" and "Stormy Petrel" - Patch.com NewsReader News Feeds 0 07-28-2012 07:50 AM
Bushing 1.5" transom through for exhaust 2" floatsome Gear & Maintenance 1 01-20-2009 07:57 PM
C270 Main Sail "stack Pack", Quick Cover", "lazy Bag" Install randy22556 Catalina 1 02-28-2007 11:53 AM
