Which? Kubota or Yanmar ? - SailNet Community
View Poll Results: Kubota or Yanmar ? if Kubota, Beta or Phasor or ,,?
Kubota 7 41.18%
Yanmar 8 47.06%
if Kubota, Beta Marine ? Phasor ? Nissin ? Other ? 2 11.76%
Voters: 17. You may not vote on this poll
 7Likes
  • 1 Post By dabnis
  • 1 Post By smurphny
  • 1 Post By rikhall
  • 1 Post By PaulinVictoria
  • 1 Post By Stu Jackson
  • 1 Post By aeventyr60
  • 1 Post By macwester26
post #1 of 10 Old 08-24-2013 Thread Starter
Need Your Input !
repower, diesel, m5424, Universal, used for sale, S29.2C, new Kubota or Yanmar-need your input on motor selection..
my email - jj_ramage at yahoo dot com.
am placing a 3 cylinder at least 20 HP motor. It will be horizontally mounted as low as possible with a CV system tying to the prop shaft.
Motor will be shifted forward 18 inches to better balance the load. I have very little gear / housing supplies aboard and she's always bow high. larger motor is a bit heavier and has lowered the stern resulting in drag as the reverse transom is slightly in the water, creating a swirl on the stern.
, and I WILL have access to the front behind the companionway ladder..
Batteries will be lowered as low as possible, and more available, not buried in the back closet.
Head will be a standing shower arrangement, and reconfigured layout.
cabin / house projects done, time to get sailing. Got the retirement summer home ready for retirement, now I need my sailing summer retirement boat done.
Kubota ? Yanmar ?
Both are based in the farm tractors / industrial power plants in the Japanese OEM's of Kubota and Yanmar.
Kubota Marinized motors= Beta, Phasor, Nissin, Universal.
Yanmar=Yanmar
Yanmar has a great worldwide parts availability, surpassing Kubota.
Kubota has more dealerships and parts availability in the USA than Kubota.
Mtugrad1985 - Jeff Ramage - recent post
Dear All,
this engine is still available. due to relocations, work, jobs, yada yada yada....it has been a long time since I've been on. forgot my user name and the system did too !
I WILL begin the process of repowering, removing the runctional and planned temporary Universal that I installed so many years ago.
Originally Posted by jefframage View Post
repowering. remodeling, rewiring
engine
fuel tank
transmission
tub
toilet
cabinet
all associated fittings available
power panel
Universal 5424 3 cylinder diesel for sale. was originally in S2 11.0 Center cockpit. Repowered my 9.2 meter center cockpit with it as a temporary repower. Moving forward with new repower now.
Well running, 5424 Universal diesel for sale or for parts.
Original in 36 foot S2 sailboat. Used last 5 years in 30' S2 Sailboat. Pushes boat at over 8 knots. no smoke , no oil, no white, good from cold start, no starting fluid, fires right up.
Fresh water use mostly, Cheasapeake Bay, and Great Lakes.
Closed loop cooling only.
Engine still in boat. I will remove
Great for cost effective repower.
I will crate, you pay for shipping pick up either from Northern Michigan or Cincinnati. Weight 385#s.
transmission available as well.
18 gallon original aluminum 18" tall diesel tank for sale.
head fittings - tub, toilet, cabinet, etc also for sale.
rebuilding, repowering, remodeling.
mtugrad1985 is offline
post #2 of 10 Old 08-25-2013
Re: Which? Kubota or Yanmar ?
No hands on experience with either. However, a neighbor had a Kubota tractor he used in his snow removal and contracting business and spoke very highly of it.
Paul T
jefframage likes this.
dabnis is offline
post #3 of 10 Old 08-25-2013
Over Hill Sailing Club
smurphny's Avatar
I have a Yanmar 3GM30F in the boat and a Kubota D950 in my Bobcat. Both are 3 cylinder engines. The Kubota is an absolutely awesome engine. It has survived hard use for many years. I doubt that the Yanmar is as anywhere near as tough. There just seem to be too many people with too many problems with Yanmars. In addition, they have no glow plugs for cold weather starting which is a royal PITA when the temp gets below 40 degrees. If I were repowering and there were a good marine conversion for a Kubota, I would definitely go that way. Kubota parts will also be MUCH easier to come by and probably a lot cheaper.
smurphny is offline
post #4 of 10 Old 08-25-2013
old guy :)
rikhall's Avatar
For me - my thoughts would be:
  1. Kubota - a tractor engine modified for a boat
  2. Yanmar - a boat engine designed and made for a boat.
I chose Yanmar and have been very pleased.
Rik
Irwin Citation 34
Mystery
rikhall is offline
post #5 of 10 Old 08-25-2013
Remember you're a womble
PaulinVictoria's Avatar
I'd probably go with a Beta. Access for servicing is well thought out.
Orange Crush
1974 C&C27 MkII
PaulinVictoria is offline
post #6 of 10 Old 08-27-2013
Stu Jackson's Avatar
They're both great engines for boats.
What you should take into consideration is the cost of replacement parts. Yanmar allows only limited access to dealerships based on your geographic location and costs are high.
You can get replacement parts for Kubota and Beta engines at Kubota tractor dealerships anywhere in the US & Canada (if you're here). A $42 "marine" Universal thermostat cost me $17 at a tractor dealer.
Who wouldn't choose THAT deal?
One other consideration: Yanmar has the mixing elbow built right into a major piece of the engine. In this and many other boating forums, I have read that they get coked up and either require frequent removal and cleaning or replacement. Kubota and Beta engines have their exhaust riser nipples off the engine, remote on a piece of pipe, and rarely get clogged. It's a maintenance issue.
Stu Jackson, Catalina 34, 1986, M25 engine, Rocna 10 (22#), Maple Bay, BC, Canada
Stu Jackson is offline
post #7 of 10 Old 08-29-2013
no longer reading SailNet
Alex W's Avatar
I like my Yanmar, but love these comments:
You know that Yanmar also makes tractors. I just drove a friends YM155d a few weeks ago. The engine block is 2 cylinders and appeared to be very similar to the block on my Yanmar 2GM20F, but I didn't have them side by side to compare.
I'm not sure if it matters if Yanmar does the marinization of their diesel engines or if Kubota sells raw engines and other companies marinize them. A good result can be had in both situations.
Alex W is offline
The Following User Says Thank You to Alex W For This Useful Post:
jefframage (09-02-2013)
post #8 of 10 Old 08-29-2013
aeventyr60's Avatar
Probably splitting hairs on this one. Which is easier and cheaper to install? The raw water elbow is a big issue on the yanmars offshore.
"Your dreams minus your doubts equals your net worth"
Life is a short journey, filled with emptiness and pain. Get all the sailing and booty you can.
aeventyr60 is offline
post #9 of 10 Old 08-31-2013
Have a go and DIY .....
I am in the throws of fitting a Kubota D1005 e
Parts are not as expensive as Yanmar the reason being Kabota does not have the words BOAT or Marine both before or after the word Kabota..
macwester26 is offline
post #10 of 10 Old 09-03-2013
CBinRI's Avatar
Never had a moment's trouble with my Yanmar.
CBinRI is offline
Tags
5424 , repower , sale , universal
Kubota rattle jcullain Diesel 5 11-14-2012 02:20 AM
Kubota Diesel Stede Gear & Maintenance 11 08-10-2011 02:46 PM
Kubota oil pressure rskaug Gear & Maintenance 4 12-31-2007 11:18 AM
overheating kubota mrkeith Gear & Maintenance 36 05-29-2007 10:39 AM
Kubota Engines P424 Gear & Maintenance 17 05-02-2007 11:16 AM
