Kanzaki tranny hiccup - SailNet Community
 1Likes
  • 1 Post By bristol299bob
post #1 of 4 Old 08-30-2013 Thread Starter
I purchased a C&C 30 end of last season. PO stated they had just changed all fluids, and I am just now getting around to changing my transmission fluid.
The tranny was working fine, but I noticed it was catching a bit when trying to shift into forward gear, so I decided it was time for a change.
The plate on the back states that it takes 0.3L of SAE 20/30. I found a pennzoil conventional 30W at walmart, the bottle says something about older model trucks and has specs of "ILSAC GF-5; API SN"
So, I pump out 300mL, and add 300mL of new oil. The catch in shifting is now gone, but, when shifting into forward gear at idle, it takes 4-6 seconds to engage. I am able to get it to pop into gear if I rev the engine a bit. Reverse engages immediately.
I thought maybe I over/underfilled, so I pumped out 300mL and added another 300mL. Same issue.
Wrong oil??? Worn plates??? Additives??? Ideas???
jerdrake is offline
post #2 of 4 Old 08-30-2013
What does a drunken Japanese crossdresser have to do with sailing?
xort is offline
post #3 of 4 Old 08-30-2013 Thread Starter
Re: Kanzaki tranny hiccup
Thanks for your interest.
Additional info: it is a mechanical "tranny"
jerdrake is offline
post #4 of 4 Old 08-30-2013
bristol299bob's Avatar
I had the same symptoms on my kbw10 Kanzaki/hurth. Not sure if this is the same trans as yours.
I'm afraid that on my case it was the early signs of death. I nursed it, changed oil frequently, and got about 2 years before it started slipping noticeably in gear.
The good news is that you prob have time. I used that time to find a good used unit. If you want new Twin Disc makes a bolt on replacement.
kd3pc likes this.
1977 Bristol 29.9
Surprise
Hull #5
Oriental NC
bristol299bob is offline
Tags
kanzaki transmission oil
Kanzaki KM2P Transmission aa3jy Diesel 1 08-30-2013 09:35 AM
Kanzaki KM4A Transmission Repair Kit svzephyr44 Gear & Maintenance 4 02-23-2013 08:42 AM
Starter Hiccup jimmy Diesel 26 07-20-2012 11:58 AM
Kanzaki km2 service manual bommers Gear & Maintenance 3 01-16-2012 12:31 PM
Kanzaki shift fork TheBlackPearl Diesel 1 02-13-2011 03:02 AM
