electrical wiring prevents engine working? - SailNet Community
post #1 of 2 Old 09-02-2013 Thread Starter
Blue Horizons
Harborless's Avatar
Just wired upp an atomic 4 and 8 had the ignition and starter backwards so that the turn key started the engine or tried to on the first switch. Re arranged the two wires and now the engine only turns over on the second switch which is correct but wont start. Sounds like it s cranking or turning over fine but no start . Could this be electrical or most likely fuel related as I seem to think?
Harborless is offline
post #2 of 2 Old 09-03-2013
Re: electrical wiring prevents engine working?
Is there a ballast resister in the run circuit?The ballast R is bypassed on the start circuit to allow for IR drop to coil while cranking.Check spark while cranking and maybe a shot of ether up the carb .If it runs for a burst of revs, its a fuel problem. Don't raw water flood the exhaust with all the cranking.
Capt Len is offline
Electrical wiring question sailak Gear & Maintenance 10 11-14-2010 10:03 PM
Electrical wiring Diagrams yelnats69 Gear & Maintenance 5 10-01-2009 11:52 AM
mast electrical wiring csilva Gear & Maintenance 11 07-28-2008 10:59 AM
Electrical wiring wchevron Gear & Maintenance 4 04-18-2008 12:18 AM
catalina 30 mast electrical wiring cptn seaweed Gear & Maintenance 1 02-27-2003 05:08 PM
