Fuel Line Replacement - SailNet Community
 2Likes
  • 2 Post By Stu Jackson
post #1 of 4 Old 09-15-2013 Thread Starter
Dave_E's Avatar
Hi All,
I'm a life long "gas" guy and the diesel thing is new to me. I like it, it's just new. I have a couple fuel lines that are just as hard and ready to snap or crack as any I have ever seen (one is actually starting to weep around the clamps). The lines are a return line from the electric pump (Universal 5424) and the feed line from the water separator. Will I have to go through the bleeding process?
Dave
Allmand Sail 31 #15 "Traveler"
GOD, Family, career
Dave_E is offline
post #2 of 4 Old 09-15-2013
Re: Fuel Line Replacement
Yes!!! Probably more than once. I like the corrosion resistant coated steel lines wherever flex is not required. The strongest most durable you can find elsewhere and watch them.
Zen is a matter of recognizing reality.
desert rat is offline
post #3 of 4 Old 09-16-2013
yes, as you change the lines you would introduce air in the system, so you would need to bleed it. Usually it's not too hard, just unscrew a bolt a little and crank the engine until you see fuel coming out. You would need to do it on the filter bolt and on injector too. Look at your engine manual how to do it properly.
Romario is offline
post #4 of 4 Old 09-20-2013
Stu Jackson's Avatar
No, No, NO, you just don't need to crack injectors on Universal engines.
Find your engine at Marine Diesel Engines and Engine Parts - Universal, Volvo, Westerbeke, Yanmar, MASE and you can read the bleeding instructions.
Your engine and our M25 series are very similar. This may help: Bleeding 101 Bleeding M25 Series Engines 101- A Summary of Links for You
rikhall and rafael block like this.
Stu Jackson, Catalina 34, 1986, M25 engine, Rocna 10 (22#), Maple Bay, BC, Canada
Stu Jackson is offline
Sewage Line Replacement weephee Gear & Maintenance 1 04-16-2012 09:27 PM
Cooling Line Replacement WanderingStar Diesel 5 12-02-2011 08:35 AM
Fuel line?? Flfishindude O'Day 1 03-03-2011 05:30 PM
SeaFurl 5 Replacement line MoonSailer Gear & Maintenance 2 12-22-2008 01:26 AM
Fuel Supply Line... avazquez Gear & Maintenance 5 09-06-2007 08:57 AM
