motor mounts - SailNet Community
post #1 of 12 Old 09-20-2013 Thread Starter
timangiel's Avatar
motor mounts
How big of a deal is it to replace the motor mounts on a Yanmar 18HP 2GM20F? How expensive, how labor intensive?
timangiel is offline
post #2 of 12 Old 09-20-2013
Senior Slacker
SlowButSteady's Avatar
Re: motor mounts
The mounts run about $150-$165 a piece. Changing them isn't terribly difficult (depending on how much room your particular installation allows you), until you start realigning the engine and shaft. Even then, it's more tedious than difficult.
Never forget them. Do something to prevent it from happening again.
Charlotte Bacon, Daniel Barden, Rachel Davino, Olivia Josephine Gay, Ana M. Marquez-Greene, Dylan Hockley, Dawn Hochsprung, Madeleine F. Hsu, Catherine V. Hubbard, Chase Kowalski, Jesse Lewis, James Mattioli , Grace McDonnell, Anne Marie Murphy, Emilie Parker, Jack Pinto, Noah Pozner, Caroline Previdi, Jessica Rekos, Avielle Richman, Lauren Rousseau, Mary Sherlach, Victoria Soto, Benjamin Wheeler, Allison N. Wyatt
SlowButSteady is offline
post #3 of 12 Old 09-20-2013
Re: motor mounts
$150 each is for the Yanmar brand. Others in the 50 range.
Sent from my rooted DROID X2
Mark
1975 Hunter30
mjf55 is offline
post #4 of 12 Old 09-20-2013
Irrationally Exuberant
Re: motor mounts
Slowbutsteady nailed it. I prefer the Yanmar mounts to 3rd party. You will need to disconnect the shaft from the transmission. When I did my 2GM20F I used a small car jack with a board under it to get the little clearance you need to slip a new mount in.
Tom K
2000 Beneteau 331
Northern Chesapeake Bay
arf145 is offline
post #5 of 12 Old 09-23-2013
old guy :)
rikhall's Avatar
Re: motor mounts
I too like the original Yanmar mounts and had to change just one. Occasionally they break. Honest!
Rik
Irwin Citation 34
Mystery
rikhall is offline
post #6 of 12 Old 09-24-2013
Re: motor mounts
Wow! If I'm seeing that right, that's an amazing failure! That post bolt is something like 3/4" diameter, right?
Tom K
2000 Beneteau 331
arf145 is offline
post #7 of 12 Old 09-24-2013
snake charmer, cat herder
zeehag's Avatar
Re: motor mounts
engines are torquey and do break mounts. we just realigned my perkins engine while in water and re-did mounts--isnt easy , isnt hard to do --must lift engine to do it..one individual did mine solo. also lifted engine slightly high er than it was and secured it--omg a secure and in place engine--i dont know how my boat will get along now---yipes.....
formosa 41, cruising tropics
zeehag is offline
post #8 of 12 Old 09-25-2013
bristol299bob's Avatar
Re: motor mounts
I went with Yanmar OEM. Pricey.
From Motor Mounts
https://picasaweb.google.com/1140510...eat=directlink
1977 Bristol 29.9
Surprise
Hull #5
Oriental NC
bristol299bob is offline
post #9 of 12 Old 09-25-2013
Re: motor mounts
I've found that if the weight isn't equal on all mounts after finishing alignment, the engine is supported on 3 points.This leaves one kinda bouncing on its rubber and fatigues the bolt faster than the others.
Capt Len is offline
post #10 of 12 Old 09-25-2013
old guy :)
rikhall's Avatar
Re: motor mounts
I was talking to a Yanmar mechanic who said he saw a boat come in with three of those bolts sheared.
I wonder what they were doing to cause that?
Rik
Irwin Citation 34
Mystery
rikhall is offline
Replacement Motor Mounts PorFin Gear & Maintenance 4 03-29-2013 10:41 PM
broken motor mounts bristol299bob Diesel 4 03-26-2013 09:54 AM
C&C 33 motor mounts barryschnur C & C 1 08-31-2011 07:48 PM
Motor Mounts on Yanmar DrB Gear & Maintenance 12 01-14-2010 07:26 PM
Stanchion motor mounts bsfree Gear & Maintenance 0 06-07-2002 10:27 AM
