False temp alarm does not go out after start up - SailNet Community
 4Likes
  • 1 Post By jimgo
  • 1 Post By 73Morgan
  • 1 Post By fryewe
  • 1 Post By jameswilson29
post #1 of 5 Old 09-30-2013 Thread Starter
Senior Smart Aleck
jameswilson29's Avatar
After pushing the glow plug button on my Vetus M3.10, normally an alarm sounds until the on button is pushed and the engine is started. Yesterday, for the first time, the alarm did not go off upon starting. The engine temperature light is on; however, the engine is not overheating, the fresh water cooling system works, and the exhaust water is not hot.
If I momentarily press the engine off button, the alarm stops without killing the engine and the engine temp light goes off, but the tachometer stops working. The engine continues to run normally otherwise. There is adequate oil, battery voltage, and coolant.
As far as I know there is no engine water exhaust sensor. Any idea what kind of problem this reveals? Bad circuit, bad connection?
jameswilson29 is offline
post #2 of 5 Old 09-30-2013
Asleep at the wheel
jimgo's Avatar
Re: False temp alarm does not go out after start up
Sounds like it might be either a bad temp. sender or a wiring problem. Given that it can turn on/off, I'm inclined to think it's the sender.
jameswilson29 likes this.
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #3 of 5 Old 10-07-2013
Disconnect the wire at the sender. If the light goes off it's your sender. If the light stays on its in the wiring.
73Morgan is offline
post #4 of 5 Old 10-07-2013
fryewe's Avatar
I don't have Vetus but Yanmar...but my panel alarm sounding on engine startup is the low oil pressure alarm which clears when the oil pressure builds up after engine start.
Both the low oil P and high T senders are switches that shut when fault conditions are met to energize the alarm circuits for the audible alarms and lights. Sometimes such switches energize separate relays that operate contacts to complete the alarm circuits. In such cases either circuit could be at fault but if momentary operation of the shutdown switch (loading the circuit to drop voltage?) clears the alarm it's more likely the relay circuit rather than the sensing circuit - if you have such an arrangement.
A high temp sender is easily tested by removing it and placing it in hot water and checking the switch operation with an ohmmeter.
The web makes everywhere the same place. - Fred Reed, from "Fred on Everything"
fryewe is offline
post #5 of 5 Old 01-04-2014 Thread Starter
Senior Smart Aleck
BUMP for UPDATE:
It was the temperature sensor on the exhaust elbow, which was fairly easily replaced. I did follow the test recommended by 73Morgan by disconnecting the sensor wire to eliminate the possibility of the panel malfunctioning. My engine is running normally again.
Thanks all for your helpful posts.
jimgo likes this.
Sailboat distress call turns out to be false alarm - The Nelson Daily NewsReader News Feeds 0 09-05-2012 05:30 AM
yanmar high temp alarm endevour Diesel 4 09-03-2009 03:52 PM
test high temp. alarm shinyscreen Gear & Maintenance 2 11-09-2007 04:41 AM
Pirate report a ?false alarm? - Wilmington Morning Star NewsReader News Feeds 0 04-19-2006 11:15 AM
US Navy says Yemen pirate attack ?false alarm? - MSNBC NewsReader News Feeds 0 04-16-2006 12:15 PM
