How to Remove Water Heater From Engine Cooling Circuit? - SailNet Community
 2Likes
  • 1 Post By Delezynski
  • 1 Post By Alex W
post #1 of 9 Old 10-04-2013 Thread Starter
Dreaming's Avatar
Hey folks,
Due to a drip in the plumbing for the Transom shower that was left unattended for years the hot water heater has become exceptionally corroded.
In preparation for its replacement and because I am afraid of the water heater failing I would like to remove it from my Universal M25XPB Cooling circuit. I know that having a hot water heater hooked up to the engine is basically an optional add on so would I just remove the hoses on the engine side? Or Would I connect the hoses or run a short hose between the two valves?
As you can tell, I'm not all that experienced with working on engines but the owners manual only tells you how to hook up a water heater, not disconnect one.
Any and all help is appreciated. Thanks!
S/V "Harmony" 2000 Catalina 310 Hull #31
Dreaming is offline
post #2 of 9 Old 10-04-2013
snake charmer, cat herder
zeehag's Avatar
Re: How to Remove Water Heater From Engine Cooling Circuit?
unfortunately that water heater would have done that without the drip. mine all did, so they were ditched. we simply undid the plumbing to and from it, making th ecold water deliver water thru circuit, and blocked off hot water lines.
have fun
you could always follow the trail of the install...backwards..i may have missed a step or two...
formosa 41, cruising tropics
zeehag is offline
The Following User Says Thank You to zeehag For This Useful Post:
Dreaming (10-04-2013)
post #3 of 9 Old 10-04-2013
Delezynski's Avatar
Location: Currently in Az. and trailer to various places.
Dreaming,
Short reply....
Just run a short hose between the two valves on the engine, as you said. That should do it. Then remove the heater and close up the lines.
Greg
Ahoyhoy likes this.
Greg & Jill Delezynski
Nor'Sea 27, Guenevere
Home page -
Youtube page -
Youtube Virtual Reality page -
Delezynski is offline
post #4 of 9 Old 10-04-2013 Thread Starter
Dreaming's Avatar
Originally Posted by Delezynski View Post
Dreaming,
Short reply....
Greg
I thought it was that simple but I just wanted to make sure. Thank you!
Dreaming is offline
post #5 of 9 Old 10-04-2013
no longer reading SailNet
Alex W's Avatar
The hardest part is pumping all of the water out of the heater so that it doesn't make a mess when you disconnect it.
Removing the hot water heater is a great upgrade. Saves dead weight, gets you back storage space, and removes an almost useless feature.
Dreaming likes this.
Alex W is offline
post #6 of 9 Old 10-04-2013
BarryL's Avatar
Hey,
When you disconnect the water lines from the engine to / from the heat exchanger, you may get some air in the lines. It may be difficult to bleed the air out. So be very careful to monitor the engine temperature for a few hours after you bypass the water heater. Make sure you know where the bleed screw is located (it should be near the thermostat) and you can open and close it. I would run the engine up to temperature, then open the bleed screw and vent any air in the system. Do this a few times. If you don't get air out, then you are good to go.
Personally, I like having hot water on board. I use it to wash the dishes, and will add some to the solar shower for washing up after swimming. My new boat has a shower in the transom, so the water heater will get even more use.
Lastly, a new water heater is not very expensive. If you can remove the old one you can install a new one. Just saying.
Barry
Barry Lenoble
Deep Blue C, 2002 C&C 110
Mt. Sinai, NY
BarryL is offline
post #7 of 9 Old 10-07-2013
Irrationally Exuberant
I guess usefulness is in the eye of the beholder. Hot water is one of those civilized bits that entices my better half to do more than just day sail with me, which makes it very useful. Nor am I immune to the delight of a hot water washup, or a warm shower on the transom after coming out of the water.
Tom K
2000 Beneteau 331
Northern Chesapeake Bay
arf145 is offline
post #8 of 9 Old 10-07-2013
Alex W's Avatar
I did check with my wife before removing it. She was fine with it and forgot that we even had a hot water heater.
We don't use the engine very much. As a result the hot water heater rarely had hot water in it. The couple of times that I actually got hot water out of it were a complete surprise to me.
When cruising we do keep a solar shower out and on the foredeck. I use this when coming in from a swim. It's only hot enough to swim here if the sun is also out, so the fact that solar showers don't work for 9 months of the year is fine.
Alex W is offline
post #9 of 9 Old 10-07-2013
Learning the HARD way...
eherlihy's Avatar
The water heater is plumbed to the engine in one of two ways. Either attached inline with the main heat exchanger and exhaust manifold, or as a hot water bypass at the thermostat. My water heater on my M25 was originally in line with the main heat exchanger. If yours is connected here, the simple fix would be to cut the 5/8" line from the heat exchanger, so that it is long enough to connect to the manifold.
Here is a pic showing the locations of the two heat exchanger hoses highlighted in red and yellow;
If yours is, as mine now is, connected to bypass the thermostat, the fix is easier, in that you need only cut the 3/8" line that runs from the top of the thermostat housing, and ensure that it is long enough to make it to the bottom of the thermostat housing.
Here is a pic with the 3/8" hose location highlighted;
eherlihy is online now
Refilling fresh water cooling circuit on a Volvo MD7B galliard Diesel 2 10-24-2010 07:22 AM
MD6A cooling water circuit.. groundhog Gear & Maintenance 0 09-11-2008 05:37 PM
Water Heater to Engine Hook-up Pub911 Gear & Maintenance 11 04-19-2008 10:55 PM
Hot water heater plumbed to genset & engine? jonlgauthier Gear & Maintenance 2 07-09-2007 02:01 PM
Connecting raw water cooling to water heater Northeaster Gear & Maintenance 18 04-28-2007 06:11 PM
