Water in Cylinders - Page 4 - SailNet Community
 2Likes
post #31 of 35 Old 10-27-2013
Mechsmith
Re: Water in Cylinders
You gotta do what you gotta do. Antiseize is another product used as an assembly lube to insure the proper tension on head and main bearing bolts and other corrodible parts that may have to come apart some years later. Especially use the antiseize on bolts that go into any light metal parts. (prevents electrolytic corrosion)
Always use the locktite on the big end rod bolts and on small bolts that attach stamped parts to heavy parts. (oil pan-cam and rocker covers etc).
Are you having fun yet?
Seafarer 29 KCB
Mechsmith is offline
post #32 of 35 Old 10-27-2013
Jolly Roger's Avatar
Thanks for the info Mechsmith.
I know one thing, itís much easier writing about repairing these heavy machines than doing it. I strained my back lifting the damn thing, so I wonít be doing anything for a week, at least until the parts arrive.
Iím just going to get it all as clean as I can and from the looks of the inside I actually think the water only got into the #3 bore, after I switched it off. There was also no trace in the oil which I drained, or the filter.
I thought I was just about through with all the big renovations and alterations on this old tubóthat would be the boat, not the wife.
We were planning our first cruise to the Bahamas, come January. But it might be less stressful if we took one on The Royal Caribbean Line instead.
Iíll let you all know the moment the darn thing starts up again.
Who would be mad enough to convert a perfectly good Ketch into a Brigantine Schooner?
Read about this major refit at
. Also items for sale.
Jolly Roger is offline
post #33 of 35 Old 10-27-2013
Don't know what your experience level is, but suggest you make a few short "shakedown" trips, especially if you have a lot of recently done work on all the various systems, before going on a long haul trip.
Paul T
dabnis is offline
post #34 of 35 Old 11-24-2013
To all members who helped me with water in my generator problem: I though you would like to hear the outcome.
I removed the head, then suspended the whole genny vertically in order to remove the pan and coní rods, This was a job in itself because the whole thing weighs about 350 lbs. Then I pushed the old pistons out the top of the block and found #3 rings completely solidónot due just to the water intrusion eitheróbecause the rings were glued in with dry oil and broke prizing them out.
I honed the bores using a Flex tool, then cleaned everything I could see, including scraping a layer of thick oil out the bottom of the pan with a chisel.
The tubes in the heat exchanger were 50% clogged with calcium buildup.
The head needed three new exhaust valves, which were pitted.
Clearly it was time for a total overhaul, never mind the water problem.
After everything was cleaned and painted afresh I began the rebuild. Three days meticulously fitting new pistons/rings and valves and replacing bits as best I could remember where they went.
With my heart in my mouth and the wife unable to watch, I finally pressed the ďgoĒ button and the darn thing fired up like nothing had ever been wrong.
#%!&*$ I didnít know whether to kick it or kiss it!
Parts cost $594.00 including three new pistons and rings, gaskets, oil, etc. The valve lapping from NAPA was another $55. The Flex tool was $45 and the ring clamp $14. With new pipes and bit and bobs total about $730.00
It now runs as smooth as a babyís bottom and quieter than before. Oil pressure 80 at startup, 60 running. Temperature 160F no load, 175F under full load.
Gauge is showing 126 volts and it does not even flinch when both ACís are on and the electric kettle is boiling for the tea.
Iíve started and stopped it five or six times to check if there was any water back-flushing, but I believe the new anti-siphon pipes prevent this. Plenty of water coming out the exhaust at the back of the boat.
Again, thanks for all your help fellas, and happy thanksgiving. Now what other jobs are on my listÖÖÖ
Faster and christian.hess like this.
post #35 of 35 Old 11-24-2013
Jolly, thanks for the feedback, always interesting to know how things come out.
Paul T
dabnis is offline
Lite propane cylinders recall Melrna General Discussion (sailing related) 1 06-17-2013 04:46 PM
Salt Water in the Cylinders capta General Discussion (sailing related) 6 03-18-2013 08:17 PM
Atomic 4 - Water in Cylinders!!! wbgent Gear & Maintenance 27 03-15-2010 10:24 PM
Firing on all Cylinders? MedSailor Diesel 7 07-09-2009 06:14 AM
Californian version of Worthington horizontal cylinders klubko Gear & Maintenance 0 09-22-2008 06:39 PM
