Injectors: Rebuild or Replace? - SailNet Community
 6Likes
post #1 of 30 Old 10-14-2013 Thread Starter
Learning the HARD way...
eherlihy's Avatar
I'm getting some soot on the transom, and suspect that my c.1986 Universal M25 (Kubota D850) injectors have never received any love.
I therefore went to my local Kubota dealer, and asked if their service department did injector rebuilds. They, in turn, referred me to three local hydraulic and truck parts businesses. None of the three list injector rebuilds as a service that they offer, or have I been able to reach them by phone.
I was able to find the injector for ~$63 on line (plus shipping). The description is;
D750/D850/D950/V1100/V1200/D1402/V1702/V1902/S2600/S2800 Injector - KUBOTA BRAND PART
Can anyone here recommend a business in Eastern Massachusetts or Rhode Island that would service injectors, and ball park what it would cost? Or, at the above price, do you think that I should swap the old with the new? My concern is that the opening pressure on a new injector may not be properly set.
For the benefit of others, the injector housing requires a 27MM wrench.
eherlihy is offline
post #2 of 30 Old 10-14-2013
Re: Injectors: Rebuild or Replace?
We paid approx $100/injector to get our Boschs rebuilt.. a new one at less money seems a good bet.
Faster is online now
post #3 of 30 Old 10-14-2013
BarryL's Avatar
Hey,
I always prefer new to rebuild. Your price is excellent. And you can keep your originals as back ups.
FYI I get some soot on the transom of my O 35 and it seems that 9 out of 10 boats have soot on theirs too. Unless you have some other problem, I would just as soon leave well enough alone. Do you get to full RPM (or as high as you got previously?) Are you now burning more gallons per hour? Has your speed at RPM decreased? And finally, how is the boat bottom and prop? If the bottom and prop are fouled it will take more force to move the boat through the water and the load on the engine will increase.
Barry
Barry Lenoble
Deep Blue C, 2002 C&C 110
Mt. Sinai, NY
BarryL is offline
post #4 of 30 Old 10-14-2013
You might try asking at a local truck depot. Or municipal BUS depot. Any freight company or parking lot where there are lots of trucks, and someone knows a local rebuild shop. Or for that matter, look for one on the internet, injectors are easy enough to ship. I'd expect a local NAPA store to know a local rebuilder, too.
The pros and cons are that if you are having them rebuilt, the quality of the work may vary. As opposed to buying new "gen-you-whine" OEM parts, which might cost more.
IIRC black soot can also mean the injector timing is off, rather than injector problems.
hellosailor is offline
post #5 of 30 Old 10-14-2013 Thread Starter
eherlihy's Avatar
... you know, I pointed a guy to where he could buy the same injector for $45 in another thread....
jimgo likes this.
eherlihy is offline
post #6 of 30 Old 10-14-2013 Thread Starter
eherlihy's Avatar
My thought is that the timing may be off because the springs in the injector have weakened over the past 26 years. Lower opening pressure, means that the injector will spray sooner, thus soot on the transom..
eherlihy is offline
post #7 of 30 Old 10-14-2013
I would have the injectors pop tested before deciding to rebuild or replace. My local guy will test them for free.
Ahoyhoy likes this.
Hudsonian is offline
post #8 of 30 Old 10-14-2013
One of None
deniseO30's Avatar
Aren't injectors just super high pressure nozzles? The pump produces the super high pressure and sends it out like the distributor on a gas engine? so I looked it up.. this is how they work.
My last project!
deniseO30 is offline
post #9 of 30 Old 10-14-2013
Tartan 27' owner
CalebD's Avatar
Get the $45 replacements.
Everybody has one:
CalebD is offline
post #10 of 30 Old 10-14-2013
Starting simple always seems to minimize pain with old engines.
Other potential causes of soot on transom:
1. Is the air filter clean and air intake unobstructed?
2. Clean bottom?
3. Proper prop size and free of entanglement or growth?
4. Is the fuel clean?
5. Is the exhaust path unobstructed (hose, manifold, etc.)? Excessive back pressure can inhibit air flow.
6. Did any injector cleaner solutions help?
7. Have you tried running under WOT in hopes of burning off any carbon buildup that might cause irregular spray patterns (assuming engine reaches rated RPM)?
I agree with BarryL that leaving the injectors alone unless absolutely necessary.
Josh
lillia28 likes this.
engineer_sailor is offline
$6,600 to rebuild Atomic 4? replace/rebuild simmonct Atomic 4 73 03-13-2017 11:49 AM
Rebuild Injectors - Fuel Consumption? T37Chef Diesel 12 03-10-2010 04:35 PM
Replace vs Rebuild? chtaylor Atomic 4 12 01-22-2009 10:08 PM
Rebuild or Replace wcshedd Gear & Maintenance 2 05-21-2003 09:52 AM
REBUILD or REPLACE bombero Gear & Maintenance 0 11-22-2000 05:55 AM
