Winterizing Penta MD6A Without Running It - SailNet Community
post #1 of 3 Old 10-15-2013 Thread Starter
Hello Everyone,
I'm just wondering if it is possible to effectively winterize a Volvo Penta MD6A without running the engine?
Even if it is a bit more time consuming, it might be the best thing to do this fall. Next fall would be different, as a few things would have been sorted out.
YRoy is offline
post #2 of 3 Old 10-22-2013
Re: Winterizing Penta MD6A Without Running It
I'll throw out some thoughts, since nobody who actually knows is responding. I would think it very hard to get everything done without starting the motor. The block can usually be drained with help of a manual to show where all of the drains are. However, no way to get fresh oil circulated, nor treated fuel. I'd really worry about water that collects in the exhaust system/muffler (may have drain there too, but not all do), strainer, water hoses, etc. Be sure to pull thermostat to fuly drain block, and I'd pull the water pump impellor to empty that area of system as well. If you have a hand crank like my old voplvo did, then that can help circulate oil, lube cylinders, etc. at least. Hopefully, others will have better knowledge.
Mike sullivan
1985 Marshall 22 catboat
mbsl98 is offline
post #3 of 3 Old 10-22-2013 Thread Starter
Thanks for the ideas Mike. So far we have been able to run the engine, so we got anti-freeze into the cooling water loop and out the exhaust. We checked the thermostat and found it had been cut out, so I'm looking for a compatible one.
I have to do some work on the feed pump. I'm guessing that will drain most of the fuel out of the engine. So I will put fuel stabilizer into the tank and just let it drip into a container.
I'm thinking I can run the starter for a few bursts and fog the engine. That could also be done to circulate fresh oil. I have yet to drain the old out though. I guess I have to find the drain plug for that!
YRoy is offline
Test running an old Volvo Penta while in storage? chefuno General Discussion (sailing related) 8 10-15-2012 12:08 PM
md6a rev meter santana30RI Gear & Maintenance 0 02-13-2012 09:31 PM
md6a thermostat santana30RI Gear & Maintenance 5 12-15-2011 04:25 PM
Volvo Penta Running Rich doffe Gear & Maintenance 32 11-20-2007 07:52 AM
MD6A Woes scurvy Gear & Maintenance 15 07-29-2007 06:55 PM
