installing a new gas tank for my 28' boat - Page 2 - SailNet Community
 1Likes
post #11 of 14 Old 10-27-2013 Thread Starter
CanadianNorth's Avatar
Re: installing a new gas tank for my 28' boat
Originally Posted by Rusty123 View Post
My quarter berth inboard wall is made of a couple plywood panels, which are screwed in place, and can be easily removed. I had them out a few months ago to replace my wet exhaust.
Thanks. I looked today , but didn't have a chance to check in detail . Looks like 11 inches clearance...
Now, the question is - if the old one can come out that way, will the new one to in that way ....
Sent from my iPhone using Tapatalk
___________________
High Hopes
1979 Glastron Spirit 28, Hull #28.
Twenty years from now you will be more disappointed by the things you didn't do than by the ones you did. So throw off your bowlines. Sail away from safe harbor. Catch the trade winds in your sails. Explore, Dream, Discover.
Mark Twain
CanadianNorth is offline
post #12 of 14 Old 01-22-2014
Diesel Fuel Tank Replacement Cal 2-29
Anyone have info on availability of replacement tanks for this boat? I'm planing to buy this boat and anticipating replacement of a tank with much surface rust.
Phil
pforeman98 is offline
post #13 of 14 Old 01-22-2014 Thread Starter
Phil
The one I have was bought second hand, but for a motorboat. I would shop around and look for a good deal, paying to have one fabricated will be pricey.
Good luck with your boat!!! I am waiting till spring to install my tank, still haven't decided exactly how to go about putting it in.
___________________
High Hopes
Mark Twain
post #14 of 14 Old 01-22-2014
My boat had an aluminum tank. It corroded and burst. I replaced it with a 'box-shaped' tank mounted under a starboard cockpit seat. The tank came from Moeller.
Moeller Marine Online - Permanent Tanks
The cross-linked polyethylene can never corrode, but I did have to fabricate a shelf for the new tank. I've used this style tank for several other projects and I'm happy with the results.
christian.hess likes this.
guyfromiowa is offline
New boat. I can't pump out either holding tank Gusnyc Gear & Maintenance 11 09-06-2015 07:25 AM
installing holding tank in Seafarer 30 Relic Seafarer 1 06-04-2013 04:22 PM
Installing inspection port, SS water tank moonie5961 Gear & Maintenance 2 06-09-2009 02:12 AM
Aluminum fuel tank - installing an inspection plate rikhall Gear & Maintenance 7 02-24-2009 03:29 PM
installing a new hatch in 33 year old boat Matt Galo General Discussion (sailing related) 7 01-21-2007 03:38 PM
